Question about GE WBSE2090A Top Load Washer
In the portion of my WJRE5500G2WW manual that refers to water temp (page 6 para. B)the text makes reference to a PerfecTemp and a TAP COLD feature. While my machine has the word PerfecTemp over the temp. selector knob, there are no markings indicating a TAP COLD feature or setting. Will the COLD/COLD setting keep the machine from adding hot water to the fill?
  • 60 Answers
SOURCE: Clothes washer overflows
take the hose off at the pressure switch and blow through it if there are no restrictions then you have a faulty pressure switch let me know how you make out
Posted on Sep 12, 2007
Master_Tech
  • 770 Answers
SOURCE: Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Posted on Mar 15, 2008
  • 1314 Answers
SOURCE: water fill temp.
check to make sure that your hot water isn't connected to the cold side this is the number one cause for your problem all washers rinse in cold so if you switch to and its hot cold then your hose is on the wrong valve just switch the fill hoses see if that don't fix it
Posted on Mar 27, 2008
  • 1294 Answers
SOURCE: GE washing machine overflows water fill will not shut off
You just have to replace the inlet valve, can do it yourself.
Posted on Jun 13, 2008
SOURCE: Slow cold water fill in washing machine
Take out the screen on the cold water side of the fill valve where the hoses attach, its probably clogged.
Posted on Mar 17, 2009
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
My Maytag washer is overflowing
Check the pump and the water level switch.
Sep 08, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Samsung rs2577sw Refrigerator
if you make the changes on the temp nob doesnt it work.
Jun 20, 2008 | Refrigerators
How to prime
http://www.keurig.com/~/media/DD2E19AE632A45BDAA55D72706420B74.ashx
^^^^ that's the owners manual.
according to it,
LCD Control Center
indicates "PRIME"
and the blue light in
the Water Reservoir
is flashing
Solution:
Completely remove the Water Reservoir and
thoroughly clean (refer to page 14). Ensure
the Water Reservoir is fully filled with water. Return it
to the Brewer and ensure it is seated properly
(refer to page 6).
If you have completed the above procedure two
times and this situation persists, contact Customer
Service at 1.866.901.BREW (2739
Aug 05, 2014 | KUERIG Keurig Platinum B70 Brewing System
Water is not cold
NO SOLUTION, THERE'S JUST NO EXTRA TUBING. Domestic refers with water dispensing feature will have a coil of plastic water tubing tucked away in the refer behind a drawer or at the bottom; it hold s cedent amount of cold water when you dispense it. However, You won't find this additional tubing in a Samsung refer. This fridge is made 'abroad' by folks don't have the same standards as the U.S. The icemaker, for instance, is found to be accepatable by their standards when it makes 72 cubes per day; HAH! We use more than that for dinner. We buy bagged ice and use a Brita pitcher. I will switch back to Whirlpool or Maytag when this thing craps out.
Aug 07, 2012 | Samsung RF265AA Bottom Freezer French Door...
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
I have a precision temp r500 instant hot water heater for my RV. When I turn on a hot water tap the igniter comes on for 5 seconds and lights the flame, as soon as the igniter goes out, the flame goes out....
Hi and welcome to FixYa, I am Kelly.
Here is the Service Manual:
http://www.precisiontemp.com/Manuals/RV500_Service_Manual.pdf
Before you troubleshoot inside the unit do the steps in para 3.3 page 7 of the manual to make sure you have good power.
There is a testing procedure on page 39 that should cover everything stated below.
Do the flow-meter check para 4.2 page 12.
Do the thermistor tests para 4.5 page 12. (See figure 5 page 18 for resitance readings)
Page 19 will show you test points on the control board.
DO NOT do the auto-calibration procedure para 4-15 page 38 until you know you have corrected the problem.
This should help you resolve the problem.
From here I think this is related to the flow-meter as you have no other failures. If there is debris in the flow-meter assembly and it stops turning / measuring flow rate due to debris; you will have the symptom you describe.
Thanks for choosing FixYa,
Kelly
Jul 11, 2011 | Heating & Cooling
The part where I pour fabric softener in it seems to be clogged somehow. I cleaned it out and it seems to still be clogged is there any suggestions that you can give me?? Please help...thanks!!
Are you sure you have water flow to the reservoir?
Does it look like the Fabric Softener is diluted with water flow?
The Service Manual for reference. Sears Parts Direct for reference.
See page 33 of the Service Manual for Bleach/Softener Dispenser Removal but I don’t think that is your problem….Rich
See page 16 of the Service Manual to go into Board Output Test. Turn on the Fabric Softener Valve and see if you hear the solenoid hum then turn on the Cold water valve and see if the dispenser fills and flushes with cold water. If not then you need to begin troubleshooting at the dispenser valve. This valve can be seen on page 36 lower left side pic and top right side pic…..Rich
Jun 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Temperature adjustment
Generally the freezer temp is the REAL temp of the unit. Fans, dampers and manual control levers let some of that cold freezer air into the refer compartment to cool it. Check your owners manual for damper operations if you have one. If you have a refer temp control all that does is control a damper to let the cold freezer air into the compartment. Also make sure you don't block off any of those vents in the refer or freezer compartment or bad air circulation can occur.
Oct 05, 2006 | Candy CPCA250K Bottom Freezer Refrigerator
GE WBSE2090A Top Load Washer Logo
145 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
