Sharp LC-19SB14U 19 in. LCD TV Logo
A
Anonymous Posted on May 19, 2014
How do I get to the tv input source - Sharp LC-19SB14U 19 in. LCD TV
Lawrence Oravetz
Level 3:
  • Sharp Master 10,558 Answers
  • Posted on Sep 12, 2016
Lawrence Oravetz
Sharp Master
Level 3:
Answers
10558
Questions
Helped
2697409
Points
29284
Select menu and choose the input you want or use the remote and push the input button to select whatever input you have connected to the TV.
No input message on APRO tv?
If your APRO 19" LCD TV is displaying a "No input" message, it usually means that the TV is not receiving any signal from the connected source. Here are a few steps you can take to troubleshoot the issue:
  1. Check the input source: Ensure that the correct input source is selected on your TV. Use the TV remote or the buttons on the TV itself to cycle through the available input options (e.g., HDMI, VGA, AV, etc.). Make sure you select the input corresponding to the device you have connected (e.g., a cable box, DVD player, game console, etc.).
  2. Verify the connection: Ensure that the cables connecting the TV to the input source are securely plugged in on both ends. If you are using HDMI, VGA, or AV cables, check that they are properly connected to both the TV and the source device. Also, make sure that the source device is powered on and transmitting a signal.
  3. Try a different input/source: If you have multiple input sources available, try connecting a different device to the TV to see if it receives a signal. This will help determine if the issue is specific to a particular input or if it persists across different sources.
  4. Test the source device: If possible, connect the source device to a different TV or display to confirm if it is outputting a signal properly. This will help isolate whether the issue lies with the TV or the source device.
  5. Restart the TV and source device: Power off both the TV and the source device, unplug them from the power source, and wait for a few minutes. Then, plug them back in and power them on again. This can help reset any temporary issues that may be affecting the signal.
  6. Factory reset the TV: If none of the above steps resolve the issue, you may consider performing a factory reset on your TV. Please note that a factory reset will erase any customized settings on the TV, so make sure to check the user manual or contact APRO customer support for instructions specific to your model.
If the problem persists after trying these troubleshooting steps, it may be best to contact APRO customer support or consult a qualified technician for further assistance. They will have more specific knowledge about your TV model and can provide further guidance or arrange for a repair if needed.
How do I change the input without A remote
If you don't have a remote for your TV, you can still change the input using the buttons on the TV itself. Here are the general steps:
  1. Look for the "Input" or "Source" button on your TV. It may be labeled differently depending on the brand and model.
  2. Press the "Input" or "Source" button on your TV repeatedly until you reach the input source you want to use. Each time you press the button, the TV should cycle through the available input sources.
  3. Wait a few seconds after pressing the button to allow the TV to switch to the selected input.
If you're not sure which button to press or if this method doesn't work, refer to the user manual for your TV or contact the manufacturer for assistance.
Vizio TV Input Menu Scrolling
Have you got any other remotes in the room that could be faulty or interfering with the WDTV.
Also:
try resetting via the side button with the unit on.
resetting to factory defaults via the internet menu.
unplugging the unit from power for some minutes (not seconds).
Do all the above one after the other before using the WDTV.
Sometimes this helps particularity after a firmware update.
The input source of the TV can be changed either through the supplied TV remote or physical buttons located on the TV itself.
Changing input source using the supplied TV remote.
  1. Press the INPUT button on the supplied TV remote.
  2. The input source screen will be displayed on the screen of the TV.
  3. Using the arrow keys, choose one of the input sources on the input selection screen.
  4. Confirm the selection by pressing the Enter button.
Changing input source using the physical buttons on the TV.
  1. Press the INPUT button located at the back of the TV panel.
  2. The input source selection screen will be displayed.
  3. To scroll through the options, press the INPUT button repeatedly. The last highlighted option will be chosen after few seconds.
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
When pressing menu on remote control I do not have a tv section listed to tune in channels
The TV channel settings Menu is usually only available when the Input is on TV. Look for a Source or Input button on the TV or the remote. Press this button and try to change to the TV source option.
Please add a comment with the make and model of the TV for additional information. (Unfortunately, many TVs don't let you change the source after pressing the Menu button and they don't always have a Source/Input button on the TV. Additionally, some replacement remotes don't even include a Source or Input button. For those with an Input button, you may need to try other codes to see if any will correctly work with the TV.)
How do I respond to a "NO SIGNAL" message?
Without knowing the TV make or model this will be a guess.
If your TV remote has an "Input Select" or "Source" button, pointit at the TV, press it and make sure the input source is set to TV or Television.
Later model TVs can have multiple input sources like HDMI, VCR, DVD, etc. They are also sometimes listed as Input 1, Input 2, etc.
2answers
How do I get rid of a no signal sign on my tv
You may have the wrong input source selected. There are a number of different source connections on the back of today's TV sets. Using the remote's SOURCE button, cycle through the different inputs until you find the one that your input device is attached to. It is common for users to inadvertently cycle off the correct input when pushing remote buttons.
The console powers up but dont come up on the tv
Do you have an input source feature on your tv? Using the remote or controls on your tv, select the the input source that is connected to your PS3.
example: If you have your PS3 connected to HDMi 1 on your tv, to view the PS3 on your tv, the tv's input source should be HDMi 1.
Manual donwload
Video input source is changed by the buttons:
1. Video Source
2. Input
3. TV/Video
4. Source
one of those four on the remote some where.
Also, chances are your TV itself will have one of those buttons somewhere.
Usually pressing it will either cycle through the inputs or bring up a selection of them, which is usually navigated by either arrow buttons on your remote or the channel up and down keys.
Lemme know how it goes.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
