Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle.
Dec 28, 2010
The error code C0202 indicates paper jamming in tray 1, C-O204: Tray-2, C-0206: Tray-3, C-0208: Tray-4. First of all, power off and unplug your copier, then empty paper from the problem tray and from the tray below it. Take out the problem tray, now you can see a paper jammed.
Please look the jam code, then only b easy to provide solution.
To check Jam code follow these steps.
UTILITY-METER COUNT
STOP 00 STOP 01
COUNTER
JAM HISTORY
Here you will find Jam code E.g J2202 like that.
F 28-01 High voltage power supply abnormality. Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit. F - 28 -02 Toner transfer wire malfunction F - 28 -03 Toner separation wire.malfunction
F 28-03 The toner separation ON/OFF operation has been performed 5 consecutive times since the separation trouble detection signal was detected at start of toner separation.Please check the HV2 unit,the transfer/separation corona unit.If there is a paper in copiymg proces when this jam occurs the machine stops after completion of copied paper ejectiom.
