When u say after replacing the battery it worked and now it stopped... the battery contacts may have corroded..... if thats not the issue.....
if u have Fluorescent lights... they have what is called a ballast. It is a transformer
like thing. They frequently go bad, more so if you leave the bulb in
long after the ends darken. if they have power in, and a new bulb
doesn't light, it is the ballast. it may have been shorting the coils for the fan as well.. check them out.....Do make sure it is getting power
before replacing it.
Is this ceiling fan/light combo wall switch controlled..? If so - does
each have it's own switch...or are you using only the factory
pull-chains for control of the fan and lights..?
What we've occassionally found when we check all connections up at
the fan box...and found them to be solid and tight..is that every once
in awhile the wiring harness that connects the light kit to the fan
housing pops loose...and this can cause your symptoms when everything
else has been ruled out. With the breaker off...have you checked for
this possibility..? If not...remove the screws (usually 3) that secure
the lighting kit to the fan housing...and double check it's plug-in
connector...sometimes the vibration from the fan can knock them loose.
We've also found that sometimes the pull-chain can go bad
internally...you can check for this by repeatedly pulling the chain for
the light kit to see if it ever makes/breaks power to the
lights....sometimes working the pull chain thru several sequences will
restore contact. If not - the pull chain assembly may need to be
replaced.
If this fan/light combo is controlled by seperate wall
switches...you may have a bad switch (or loose wire at the
switch)....but only testing will confirm that. Be sure to do all
examinations with the breaker off.
So - where you have checked the pull chain and wiring harness for the
light kit.....and ALL power connections up at the ceiling box (as
above) and have assured that the light kit is properly connected to a
power wire up at the ceiling box (on most fans - the lighting section
is a blue wire, the fan is black and they both have a white common. If
you have a 3 wire feed up at the ceiling box...the fan's black will
hook to the power black, the lights blue will hook to the power
red....and the units white to the power white. If it is only a 2 wire
feed in the ceiling box....the fans black and the lights blue will both
hook to the power black)....and ALL that appears to be okay...then
there may be some kind of defect in this fan (or an internal problem
that will take much more detailed troubleshooting)...a new unit may be
the easiest (and quickest) solution....short of completely taking the
entire unit apart for detailed bench testing. They just don't make them
like they used to Al...
if u feel i ve spent my time for u... kindly rate my service.......
good luck.... if i were u ..... if all the above fails i wud go for a new fan..... have a nice day
