Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerator is somewhat cold as is the freezer side but the freezer side is not generating freezing temperatures. Same temperature btw the refrigerator & freezer. Model 596.50392001. Any suggestions?
  • bmowrer1774 Jun 27, 2009
    Thanks for the recommendation. Before trying your recommendation, I removed the lower panel inside the freezer, exposing the fan, cooling coil & evaporator. There was no frost on the cooling coils and the cools were not cold. Then I manually advanced the defrost timer, as you suggested, until the defrost cycle started. I confirmed that the defrost cycle began by confirming the heating element below the coils was hot. After ~ 30 minutes, the defrost cycle ended and the compressor restarted. The freezer took >12hrs to return 32F and the refrigerator returned to a cold temperaure (~40F). However, the next morning, the freezer chamber had returned to temperatures in the upper 40s again, resulting in a similar temperature in the refrigerator. I'm not sure if the freezer is entering into a defrost cycle too frequently (how often should the freezer defrost??) or is there an issue with compresser? Could it be the defrost timer is forcing too frequent a defrost?
  • Kenmore Master
  • 4,655 Answers
Your refrigerator has a defrost timer located near the floor and behind the kick plate. Remove the kick plate grill and turn the timer slowly clockwise until refrigerator compressor stops running. Leave it there for about 30 minutes or until refrigerator restarts. During this time the refrigerator should be in the defrost cycle. Open the freezer and you will possibly hear a crackling noise or the noise of water sizzling as it drips from the evaporator to the defrost heater. If your refrigerator does not restart after this time then turn the timer again slowly until the compressor restarts. If you do this then the timer will need replaced If no defrost takes place during this time then we need to move to the rear of the freezer and unplug the refrigerator and do some test on the defrost heater. Let me know how this worked out for you. The part number for your defrost timer is 10530703
Thanks, Sea Breeze
Posted on Jun 24, 2009
  • 1 more comment
  • John Tripp
    John Tripp Jun 24, 2009
    Here is a photo of part number R0131577 Defrost Timer same part as 10530703
  • John Tripp
    John Tripp Jun 27, 2009
    Until we change the defrost timer I don't believe you will get true functions with your refrigerator. Until replaced I would advance it to get the refrigerator going. It has too many contacts that could give us false readings and a misdiagnosis. It will stop and start and stick on defrost. Replace it and we need to go from there. The part number for the Defrost Timer
    P/N: R0131577 on my site http://servicepartstec.blogspot.com/
    cost less. Sea Breeze
  • John Tripp
    John Tripp Jun 28, 2009
    I have not heard back from you in a while. Yes there could be an issue withe the start relay on the compressor.
Why is the refrigerator side is freezing food
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
Nov 01, 2017 | Refrigerators
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 16, 2012 | Frigidaire Refrigerators
Fridge temperature is too cold, food id freezing. freezer seems fine. even adjusting the fridge temperature up to 1 does not change the temperature. seems to be stuck at 30F.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 10, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Refrigerator is somewhat cold, but the Freezer doesn't freeze ice?
Hi...
If you want to fix your problem, you need to check this:
  • Check the temperature settings
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condenser coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!
Regards
PCmania
Jul 12, 2009 | GE Refrigerators
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
335 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
