Question about Electrical Supplies
Generater run with low oil,cant pull starter cord more than a couple of inchs,I think the motor is locked can it be repaired
  • 237 Answers
Probably, but you just can't know till the engine is torn down for inspection. Will have to replace the rod, possibly the crank. Look also for damage to piston & cylinder wall. You might be better off with replacement engine.
Posted on Jun 24, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
HELP! My Stihl TS400 pull starter is stuck or seized as it won't budge an inch when I try and pull it. Is there anything I can try to free off the pulley or does it mean it is seized and not worth fix
You may get a compression lock of some kind on these engines sometimes (2 stroke and 4 stroke) and I have had this happen a couple of times when trying to start them thinking that the mechanism had seized up when it had not. You pull the cord and it locks solid. You cannot turn the engine over. I have always managed to eventually free it though.
What I would do in your case is remove the spark plug and then see if you can pull the starter cord.
Dec 28, 2015 | Stihl Saws
I already broke one recoil starter assembly on my Astra Korea 3 kVA generator. I can start the generator, but with great effort. It takes about 6-8 pulls, and there's so much resistance that I can actually...
The easiest test to run on the generator is to remove the spark plug and see if it pulls easier. If it does then it is a compression problem. I doubt that is the case. If it does not then you need to take the generator off the motor and see if it still pulls hard.
Jun 20, 2014 | Electrical Supplies
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
I cant pull the cord, everything seems to be frozen
It is possible the motor is seized or the pump component has jammed. The Honda Motor usually has an oil minder(wont start if low oil). So that being the case you may have a problem with the pump. If you are handy and have internet it is possible to download a parts/repair manual for the type of pump involved. Otherwise take it to a repair shop. Sometimes these pressure washers are more costly to fix as compared to a new one..
Nov 06, 2011 | Honda Maxus Prosumer MX5223 Pressure...
The starter Pull Cord on my portable generator will not pull easily or smoothly. I can get it to start but every other try the cord will not budge. I think I overfilled with oil on my last oil change. ...
Czorbach... Sadly it is said
"it is more harmful to RUN with too much oil
than none at all"
That is like saying each one might have a value...
Neither does.
Yes it is HIGHLY LIKELY
the engine COULD have been seriously damaged.
The simple truth is that oil... DOES NOT COMPRESS.
The crank-case is a closed area... HOWEVER
I'm guessing the case has a dipstick, fill plug and
several weaker spots that should clearly
fail before serious damage was done to
YOUR METALIC internals...
Perhaps you are just having an ugly coincidence
and your starter pulley was merely ... bent/damaged
during your PREVIOUS MEELEE...
I CAN NOT actually imagine you were REALLY able
to RUN your engine... ALL STUFFED UP like a
HYDRAULIC JACK.
Honeywell HW1000i Portable Inverter Generator Owner Manual
https://en.wikipedia.org/wiki/Carnac_the_Magnificent%E2%80%8B
May 13, 2017 | Honeywell 900W (1000W Max) Inverter...
Black Max 7000w 8750 surge 13hp. pulled start cord twice very hard then would no longer turn over engine, locked.
Pull the spark plug out and try pulling the cord. Sometimes it gets flooded and the cylinder fills with fuel and hydro locks. When you pull the cord and there is fuel/oil in the cylinder, it will fly out when you pull it. Stay out of the way.
If that is not the problem ( I think it is though), double check the oil level. Check the color of the oil, it should not have any silvery color. It should also not be overfull. If it is......smell it......, does it smell like gasoline? If it is overfull, and smells like gas, you have a carburetor problem. And if you do chances are you already know that, it will leak and drip, unless you shut the fuel valve off.
If everything seems fine...,and you still have a stuck motor, you will need to seperate the generator from the engine and determine which one is actually stuck.
Hope it's just a leaky needle and seat in the carb. causing your flooding.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 18, 2010 | Powerware Electrical Supplies
The pull cord is locked, can only pull out 5 inches....why?
Could be motor locked up or cord caught in the rewinding mechanism. Remove top engine cover and see if cord pulls now. If not then in winder. If it does see if you can turn the motor over by hand with cover off. If not maybe engine locked up. Did the engine run low on oil? if so when motor cooled, things may have locked up. Try removing spark plug, and light oil to cylinder and let soak.Turn engine with wrench.
Jun 30, 2010 | Briggs & Stratton Power Products 5,550...
The motor's pull start seems locked. How do I
Usually what I do first is pull the pump off the engine. After doing that use your hand to back the motor's shaft up about a quarter turn. Then without the pump on try to start the motor. If it starts put the pump back on and try to run it. Sometimes the crank and piston get set just perfectly so you cant pull it over. If that doesn't work post here again and I will help you further.
Jan 14, 2010 | Northstar Professional Series Pressure...
Chainsaw pull cord won't pull to start
Simply check to see if motor is locked is to remove spark plug and try to pull start. If motor turns, then he may have gotten gas in cylinder and created hydraulic lock. If moto does not turn, it is just a few screws more to take side cover off and see if rope caught in pully. In fact, you may want to take side cover off first, and make sure rope pulls out of housing, and self winds, like it should. At hat point, he can simple turn flywheel by hand to see if motor is locked up.
If the motor is locked up, you can put small amount of motor oil, (half a tea spoon) into spark plug hole, let it sit half an hour or so, and then try to work the flywheel back and forth to break it free. This condition may have been caused by running straight gas, not mixed. And, even if motor frees up, it may still need to go in for repair.
We have a couple of Poulin Pros at this saw mill where I work, and have had the piston lock up more than once, from guys dumping in straight gas. Sometimes we'ra able to free up piston, and make saw run again. And sometimes we end up tearing it down and repairing piston ring. Good Luck
Nov 19, 2008 | Poulan Pro Chain Saw 46cc 20"
Electrical Supplies Logo
223 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
