Question about Sony Playstation 3 (PS3) Console
Will not eject
Disc will not eject either by remote or manual button
    Problem Solver:
  • 6 Answers
Ok there is a way to get it out you have to cut off your ps3 then turn it off from the back put your finger on the eject button and flip the switch it should eject the disk and put the fan on high for a few seconds then turn off make sure you cut it off at the back after that then start back up:)
Posted on Jun 26, 2009
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Why won't the Blu-ray player power up, with either remote or direct input?
Your eject drive is locked up and Your disc will have to be removed manually. It's Blu-Ray Up-Grade time. Good Luck.
Sep 28, 2014 | Televison & Video
How do you eject a DVD without an eject button on the sony rmt b10a remote?
Why would you want to do that? You still have to walk to the machine to take the DVD out.
Jul 31, 2014 | Sony rmt-b104a Remote Control
Cannot find eject button or what to use to eject DVD from bauhn atv-32hdc1n. Lost the manual first time to use DVD and now cannot get it out. Hope you can help
On page v of the manual (if you had one), under the heading "DVD Mode", the first item in the list is an up-arrow symbol, with "Press to eject the disc" next to it.
That's simple enough, IF you have a user guide. But if you don't, and you weren't familiar with standard symbology for these types of buttons, you would be stumped by the moronic design of the remote control.
The up-arrow button is on the top row of the Remote Control buttons, next to the red Standby button. It's a standard Eject symbol, but not only did they just assume you'd know that, they obfuscated the situation further by marking it as "TV/Radio". So if you weren't familiar with the symbology, you certainly wouldn't be looking for something marked TV/Radio to eject a DVD.
But there's another catch: The up-arrow/eject button will only work if your Source is set to DVD. If for any reason you switched away from the DVD before wanting to eject it, you would find that the Eject button no longer works. You have to switch back to Source = DVD, then press the eject button.
IMO, there is no excuse for a Remote Control design that can't be figured out without the manual.
Aug 28, 2013 | Televison & Video
U99 error code
The remote isnot going to eject the the disc, You have to press the eject button on the unit, To get the disc to eject,
Nov 26, 2012 | Panasonic Dmr-eh67e Pal Dvd Recorder With...
I've recently bought a Sony DVD/ CD player DVP-SR650P. Its accessoies includes a remote RMT-D187P. The remote does not have an open/close/eject button. How to eject the disc tray with the above DVD player...
There is no eject etc button on the remote control because what use would it be? To insert or change a disc, the operator would have to be in reach of the drawer with a disc to hand.
Mar 06, 2011 | Televison & Video
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
156 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
