Question about Mitsubishi WS-55813 55" Rear Projection HDTV
Timer light i have a Mit. ws-55815... i woke up today and the grean timer light is flashing over and over....i unplugged, pushed the reset for about 10 sec. pushed and held the power button and it just wont turn on
  • 1 more comment
  • REDRIDER416 Nov 04, 2007
    TV WAS WORKING FINE LAST NITE WENT TO ON THIS MORNING NOTHING JUST LIKE IT WAS UNPLUGGED
  • Anonymous Nov 22, 2007
    got up in the morning tried to turn on the t.v nothing the green lite is blinking unpluged it plug it back in but nothing its a 65 in. diamond series
  • famguy Jan 12, 2008
    same prob. just inherited tv. blinks for more than 70 sec. light wont stop blinking and tv wont turn on. held the reset button and menu button. could you plz e mail me with a fix. atchley1229@yahoo.com -mike
    Genius:
  • 1,030 Answers
Does the light blink for more than 70 secounds? if it does go off after 70 seounds the keyboard lockout feature may be engages to unlock press and hold menu on keyboard for 10 secounds. If the set contiunes to blink after 70 secound after plug in then you maye have power issues or a possible bad digital board
Posted on Jan 08, 2008
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi T.V WS-55815 How to go INPUT , NO
Please check with your remote , the input or video 1 will be found on the source or menu selector which can be scrolled with a view on the display.- on screen.
Check this out.
Sep 25, 2011 | Mitsubishi WS-55815 TV
TV will not turn On
Call a good TV Tech and have him check for vented capacitors in the DM module or blown pico fuses on the -24 and the +24 volt lines.If fuses are blown,it indicates the convergence amp IC's are bad.The fuses solder into the board.
Jul 28, 2009 | Mitsubishi WS-65711 65" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Blinking timer light on mitsuWS-55815
My mitsubishi little green timer light will not quite flashing and the tv will not come on.
Apr 01, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
