Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Screen partical fade
The bottom of the screen fades away - when I hold the left side of the screen the display comes back in full.
  • 382 Answers
The inverter cable or lvds cable may be severed. I've recently replaced a display on a Titanium for this reason. If your machine is under applecare, you should submit it for lcd panel replacement. If your machine is not covered by applecare, they may charge you in upwards of $700 for the procedure. Depending on 3rd party apple service locations in your area, you may have to source the part off your local craigslist, ebay, or a 3rd party site like If not, you can ship it to us in NYC.
Keep me posted
Posted on Nov 05, 2007
  • Keith Seekwhensir
    Keith Seekwhensir Nov 05, 2007
    Usually it means the cable has gone faulty, or is being pinched or stretched, as it runs from the display and though the hinge bezel ( along with the BT and airport cable ) to the logic board, hence it appearing as a short circuit.
Vizio TV has a horizontal 2mm black/multicolor line.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 27, 2016 | Vizio Televison & Video
Ti 84 plus screen faded away
If you cannot see anything on the screen, you may need to adjust the graphing TI 84 calculator contrast :
1. To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold Down-arrow key until the display is sufficiently light.
Mar 22, 2012 | Texas Instruments TI-84 Plus Calculator
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
The picture bleeds down to a black screen. At
Ur main backlight video board is the cause,must replaced.
Oct 25, 2009 | Sanyo DP26746 26 in. LCD Television
Full Color fading to blue then screen turns off. Repairable?
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the blue will be on the bottom left--it does vary
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Blue Screen control.
8.) Best way to do this if the set is on is on a video input with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----if you get it to turn on this way turn the blue screen back down slowly until the blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the blue screen down a few times to get it to stay on.
I do this here for free and if this helps you at all give me a vote here--it costs you nothing.
Regards, SD TECH
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Color fades at bottom of screen
Although it is possible that your monitor is defect, you should first run a monitor test to see if you just need to adjust some of the settings. Go to this webpage and just follow the instructions.
The test are done best in full screen mode (F11 in most browsers).
Do you have any sources of magnetic fields next to the monitor (speakers, halogen lights, sometimes even a cordless phone can cause distortion).
If you can, connect this monitor to another computer and see if the problem persists. This way you eliminate any hardware related issues (cable, video card).
If you have any more questions (also regarding the results) come back here and leave a comment. I will check back and see what else we can do.
Feb 24, 2009 | Acer 22" X223w LCD Monitor
My sansa e250R not working
Hi try this for me and let me know if you can put it in recovery mode if it does go into recovery mode dont do anything just let me know then ill tell you what you need to do next ok
1. with it switched off put key lock on
2. hold down rec button on left hand side
3. whilst still holding rec switch it on still holding down rec
4 it should now say recovery mode
let me know when you get this far ok
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Screen has horizontal lines and fading
bad screen u have to get new screen take it apart from top side pop off top panel 2 screw on back use flat head unscrew screen get new one one ebay ect ok cheak cables in ther also thx nick
Feb 09, 2008 | Computers & Internet
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
118 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
