The terminal is set internally to settle each day on it's own. you can have this turned off if you don't like the feature.
if you select the 0 key or press enter if 0 does not take you to configuration menu. enter your default password or 1 alpha alpha ( key is above the 2)66831 enter, then select the purple more key until you see merchant id.
select merchant id. then press next until you see auto settle time, press select when you see auto settle time. remove the time using backspace key, select exit and save changes red x to main screen. the auto settle should be removed now. but if you do a download you will lose this information so it is best to contact your processor to have your file updated.
SOURCE: Inserting Paper into Verifone Credit Card machine
I do not have a pictur eor video but it is not difficult. Open printer door, place paper in printer with the paper coming out towards the keys of the terminal from underneath the roll. Pull slacked paper over keys of terminal and shut printer door.
SOURCE: Verifone vx510 showing "no master key"
it message show in the pinpad or in the point of sale??? if it is in the pinpad you must re-enteder the master key number into a pinpad.
SOURCE: Verifone VX510
Yes he is somewhat correct. At the main sale screen hit the option 6 usually the password is 1 Alpha Alpha 66831 if it gets you to the Terminal Phone COMMs screen it is good. Choose phone then next and choose PBX code that is what needs to be dialed out from your phone system to get an outside line IE: 9,,8,... once that is edited choose enter then exit if that doesnt work at teh main screen hit the more key or the tip key until you see other setup then the password again. 1 ALPHA ALPHA 66831 hit the tip or more key again until you see COMMS. Select it then hit next until you see baud rate hit edit and that field and then next until you see 300 hit enter then exit save changes hit ok then the red X key to get back to the sale screen try that.
Other fixes as well but it needs phone conversation.
Call me at www.greenlightpayments.com ext 105
