Question about Weather King 10AJA4201AH Air Conditioner
I have new conpresser
And it was just charged its only cool not cold
  • 146 Answers
Well it should be about 56 degrees coming out of the vent. and might be not fully charged or you have a leak.
Posted on Jun 24, 2009
2008. Why isn't the air conditioning working better?
When the compressor is replaced it should have had at least 2oz of oil inserted into it. The entire system should have been flushed to remove any foreign debris ( especially if the original compressor/clutch failed ). The system then needs to be vacuumed down to remove any moisture for a minimum of ten minutes and then leak tested to ensure vacuum holds. The system is then filled with the proper charge of freon and oil and then monitored for guage pressures and signs of leaks to ensure proper operation and effective cooling
Jul 16, 2015 | Toyota Camry Cars & Trucks
True gets too cold
If it doesn't respond to the adjustment on the temperature control I would think it has an improper refrigerant charge. You need to remove the existing charge and weigh in the new charge. It has to be exact for the temp control to respond and sense properly. Some times when the refrigerator is slowly losing its charge from a leak you will have long running times and the refrigerator will get too cold and then suddenly wont cool at all. Check the condenser to make sure that its plenty clean. An overheated system will cause long run time. Temp controls don't generally fail and I would be slow to just change it without looking the system over good for leaks. You may have to call someone in to check it out. Hope this helps and good luck.
Jul 08, 2014 | True GDM-69 Refrigerator
After installing my Klimaire 30912-H216 mini split, one of the three evaporators is cooling but not as much as the other two.
actually the hi side smaller line should be hot to the touch and the low side larger line should be cool or cold, sounds like a low charge without any further information, the small line coming off the compressor is the liquid compressed it should be hot, the large line low side returning to the compressor is the gas after the coils and returning it should be cool or cold depending on load
Jul 06, 2012 | Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 19, 2017 | Heating & Cooling
2001 hyundai santa fe air conditioner the air conpresser works ad the blower works but can't get cold air.
might be the cooling gas freon
or could be simply the clutch that engaged disengage the compressor has a problem with its solenoid
Jun 14, 2011 | 2002 Hyundai Santa Fe
Got spark and gas can't get it running what is the conpression supposed to be
i have a honda power washer EXHA2424, I replace new spark plug, new gas., cleans the cabureetor, and it still won't start please advice me what to do
May 21, 2011 | Devilbliss DeVILBISS Devap DVH2600...
AC blows, air is cool not cold, went from very cold to blowing cool air overnight. Can the system be charged. How much $ about.
yes, you can charge it yourself for less than $20. Purchase a large can of R-134a and a recharge hose. Follow instructions at http://www.fixya.com/cars/r5833579-auto_truck_c_recharge and let me know if you have questions
Sep 10, 2010 | 2000 Chevrolet Cavalier
Freezer & refrig not cold
change the filter. to do this recover the freon(gas), remove the filter , replace it by new one; do the vacuum and then charge again. Work must be done by a certified technician. do that at your own risk
Aug 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
AC doesn't get cold. 1999 Plymouth Breeze
you may need to have the freon charged. although its full doe snot mean it is charged. also try buying new hoses for it that are more heat resistant becasuse the hot weather
Aug 07, 2009 | 1999 Plymouth Breeze
Dometic air conditioner not blowing cold air.
make sure fan on auto if ok and unit on cool check compressor coming on if ok bad cooling unit
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
Weather King 10AJA4201AH Air Conditioner Logo
61 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
