Question about SanDisk Sansa e270 MP3 Player
Where can i get the sansa e270 driver... my system does not recognize the player.. it says found new hardware wizard
  • 30 Answers
Well I found this... http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
That should work, but I can't say for sure...
Posted on Jun 24, 2009
Sansa e270 it lost driver
Go to Sandisk's website and get the software you need. If the reinstall fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 21, 2009 | SanDisk Sansa e270 MP3 Player
My sansa e270 6gb is frozen and wont go past the refresh database screen what can i do to erase all the data that is on it and start all over
I'm always hesitant to give this answer, because if it's done wrong, you can do more damage to your player, but the answer is: you need to format your player. I would format the player from inside the player's settings menu - but if it's stuck on Refresh database, you may not be able to do this. Follow these steps in order:
-Tha Mp3 Doctor
Feb 15, 2009 | SanDisk Sansa e270 MP3 Player
Installing trouble with Sansa e270
http://www.drivers.mrjuan.com/driver-5949-sansa-e270.html
Go to this link and choose the OS your computer is running off of and the software should be on there somewhere for download.
Dec 26, 2008 | SanDisk Sansa e270 MP3 Player
Entering recovery mode is not possible
Disengage the lock switch, then try this: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 03, 2008 | SanDisk Sansa e270 MP3 Player
E270 isn't recognized by windows; can't enter recovery mode
Are you running Vista? shame on you for not checking to see if your player is compatible with it
If you are running XP:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Wizard.
Jul 01, 2008 | SanDisk Sansa e270 MP3 Player
Windows xp professional does not recognize device
XP Professional tends to have problems with all devices when you are connected to a network. Disconnect your Sansa player from computer, turn it off, hold in the volume + button and reconnect to the computer. Continue holding the volume + button until the "Found New Hardware" Wizard pops up - XP will load the needed drivers.
Apr 12, 2008 | SanDisk Sansa Clip MP3 Player
Need to know which driver to install
Let the hardware wizard search your windows disk or point it to c:\windows\system32. It installed the usbstor.sys drivers for mass storage devices.
Jan 05, 2008 | SanDisk Sansa e270 MP3 Player
E270 sansa
-Tha Mp3 Doctor
Dec 12, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
139 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
