Question about Euro-Pro Shark SC-505 Handheld Steam Vacuum
SC505H Portable Steamer with broken hose in the handle
I have a Shark SC505H Portable Steamer that steam comes out around the "trigger" when depressed. I disassembled to see why the hose as plugged, and found the hose out of the on/ off valve was split. Anyone know of a high temp rubber hose material for repair. I think it is 1/8 ID and 1/4 OD. Called Euro Pro and 1 they didn't even see a problem with a potential hand burn issue, 2 they charge for all out of warranty repairs even when product is defective (was only used 1 or 2 times previously) They don't sell parts for these. I think they put more money into advertising than in product materials based on several on line problems
I also have the Shark steamer worked great for a while lots of pressure but then pressure started coming out of the insert part for the wond not sure if its the o rings that need replaces or just the wond it self can any one help me
Posted on Sep 17, 2009
My shark steamer is foaming and no steam is coming out
You cant put soap in the steamers, only water. Clean out water container and start new. Also, clean hole where steam comes out with something thin. Make sure it is heating up enough to produce steam, otherwise heat assembly is broken.
Mar 08, 2017 | Shark Vacuums
Shark portable steam cleaner heats up but does not produce steam
Built in thermostat...sounds like you need to buy a new steamer.
Dec 12, 2013 | Vacuums
My shark steamer is not heating or steaming
I posted this video explaining how to clean the heater core.
http://youtu.be/S4NglGXVv50
Tons of water on the floor might mean that an internal hose or hose clamp has failed. Once you have it apart you can assess and replace the hoses by taking the bad hose to the auto parts store and asking for an appropriate sized replacement.
Dec 18, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Parts and accessories for my Euro-Pro Shark
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories heatman101
Jun 04, 2010 | Euro-Pro Shark SC-505 Handheld Steam...
I broke the handle part of the shark steamer #53101. I don't have the book to try to tell you the parts I need. Can you send me a picture or a copy of the steamer. It is purple. The above number may not be...
Ann there are very few parts for these...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-pro Shark steam mop has a broken handle.
I have broken 4 shark handles, have repaired them its a pain. remove the screws on the handle end of the head pop out the broken handle part, drill a 3/16 hole into the part tap 1/4 inch threads use a countersunk head 1/4 inch bolt screw it together put epoxy on the inside to lock threads reassemble. its a pain. two small keepers lock the swivel together pry out with a screwdriver carefully dont loose them. I broke one shark handle when it was brand new. this repair works good if you like alot of fooling around
Jan 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
This is a EURO-PRO X Shark Steamer Model S3325, there doesn't seem to be any power in plugged in, no lights on the handle. Bad switch or is there a fuse?
There is usually a heat sensitive fuse link installed in the handle and is incorporated in the cord connection. If the machine gets too hot or is run while dry, the fuse can blow. You would have to replace the fuse, as they are not resetable.
Mar 28, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
No steam coming out
The fall might have damaged or moved the trigger so that it does not depress the valve on boiler.
Try removing the screws which hold the handle together. The cap needs to be removed to allow the handle to separate.
Once the handle is apart check the trigger piece looking for any broken parts.
Jul 07, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Shark SC-505 Handheld Steam Vacuum Logo
563 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
