Question about Sylvania 6319CA 19 in. Combo
No sound on TV or at the earphone
I have a small 2001 model JVC tube type TV. How do you turn speakers on? I have no sound at thr tv or through the eae phone.
W
hat can I do to get sound?
Thanks. I will get a new tv.
Posted on Jun 25, 2009
Can't get any sound?
* Check your sound (earphones) plug if it's plugged all the way in. Most CPUs now days don'e come with a built in speaker.
* If your using a laptop (with built in sound) then check the menu for your hardware set up and check if the internal (or if your using external speakers/head phones then select external speakers. You many need to identify and select the type of speakers; headphones, small, or large speakers.
* Check settings for the type of sound you want; normal, theater (simulated).
* Check if the blue tooth is on. This should be off if your not using bluetooth head phones or blue tooth speakers. Your internal speakers will turn off anytime the blue tooth is on AND connected to a blue tooth device.
* If this is a TV? Especially a newer 'Smart' TV then go to the menu and check the sound set up again. There are many choices on how sound is broadcast to a speaker or sound system. Many of the newer TVs have speakers as an "Option" and must be set up during the initial install. (This is because your basically setting up a computer/TV/sound system when before it was just a TV - no computer.)
* If this is a older TV connected to a cable box. Especially an old analog (tube) TV then you must contact your cable company for a digital converter box. (or just get a new "DIGITAL" TV for High Deffinition that your paying for but don't have an HD TV to watch.)
* Did I cover everything? DVDs, VCRs, CD players, all have separate A/V (audio/video) cables that must be check or replaced. Photo/IR plugs and cable needs to be checked if they seat properly in socket. Replace or up grade to better cables.
* Finally, If your playing a digital movie on a computer and you get video but no sound (or no vid but got sound) then the app or program your using is not able to decode the video properly. Try using your web browser to play and/or search out the correct player for the format your using. Harder, you may need to find a video converter to a more common format.
Aloha, ukeboy57
May 11, 2018 | Computers & Internet
Vibration through speakers on my jvc home cinema system
try tightening the screws on the cabinets or buy a full set of
Wharfedale Modus Cube Main Stereo Speakers to replace the bad ones
Mar 23, 2014 | JVC Audio Players & Recorders
My JVC LT-37EX17 flat screen TV doesnt have sound?
If the earphone jack works the set is ok---that socket can cause this issue if dirty or worn inside.
Check also in menu internal speakers are not turned to OFF or external.
Dec 22, 2012 | JVC LT-37X688 37 in. LCD HDTV
My jvc tv model LT32A80SU has a picture but no sound what could it be
Aside from a audio circuit problem:
Look to see if the set has a earphone jack--sound that way?
If set has rear connections do you have sound with a DVD player etc?
Look in the main menus for a setting that speakers are not turned OFF>
Dec 06, 2012 | JVC Televison & Video
JVC TV LT32A80SU HAVE PICTURE BUT NO SOUND
Speaker is off
Most of these combo units do not have a speaker ON or OFF setting but look anyway.
If the set has a earphone jack that may be the problem--see if works with earphone plugged in.
The socket the jack goes into can get flaky as when jack is inserted it turns the sound OFF.
Also put your ear right to the speaker to see if anything at all is heard--the speaker could be bad--but check the above first.
SD TECH
May 27, 2012 | JVC TV-13142 13 in. TV/VCR Combo
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
Dear Sir, In my aiwa tv there is no audio sound (,two speakers ) how can i rectify the problem, Pls any one help me to sort out the issue. Rgds, Jayaprakash.
Hello
You just check whether its speaker has damaged or not. You can check it easly. Just place your ear very near to the speaker side of your TV, and switch on the TV with its panel on-off switch, not by remote hanset. If you hear a "thumb" sound from that side of the speaker, you can make sure that the speaker is OK, and the fault is inside the circuit board of Tv.
If there is no "thumb" sound, open the TV and check the speakers for continuity. You can check the speaker with a troch cell, by touching its poles to the leads of the speaker, with attaching a pice of wire to the cell. If it is found faulty, replace them with an identical type and resistance, Its impedence [resistance] will be marked on its magnet. Choose an exact one.
If speakers are found Ok, and still there is no sound, if your TV is equipped with an earphone socket in front panel, push in an earphone pin into it, and check whether there is sound output from it or not. If there is sound output from it, and you can't get it through speakers, the earphone socket is faulty, and replace it.
if there is no sound from the earphone socket also, just goto the sound output section of the circuitboard of your TV. You can locate that section by following the speaker wire. Look for any loose soderings first. I advice you to resolder all the soldering points of sound output Ic, before replacing it. After resoldering, still there is no sound, check the input supply voltage of that Ic. If it is not there, check for the reason. if it is there and still no sound, sound output Ic is faulty, and replace it with same type and number.
If you need anymore assistance, get me through Fixya. OK.
Dec 13, 2010 | Aiwa F2000 20" TV
No sound
Hello
First you check the speaker of your Daewoo Tv. To check the whether the speaker is good or damaged, place your year very close to the speaker side of your TV, and switch the TV by its front panel power switch, not by the remote control. If you can hear a "Thumb" sound from the speaker, as the TV is switched on, the speaker is good and you have to to further. If not speaker has got damaged and have to be replaced.
If your TV is provided with an earphone or headphone socket at its fron panel, insert a earphone or headphone pin into it and listen whether there is sound coming from it or not. If ther comes the sound, it doesnot comes to the speaker, means that the headphone or earphone socket is faulty. Replacing it will solve the problem.
If there is AV OUT from your TV, connect it to an amplifier or so to get the sound. If there is sound and no output from speaker, means the Audio Output IC inside your TV is faulty.
Just locate the audio output Ic, and replace it with same type and number. Audio Output IC can be easly located ans speaker wire goes to that section, and follow the speaker wire. locate it. If you need any more assistance, feel free to contact me through Fixya. OK.
Dec 07, 2010 | Daewoo DTQ-20U9SC TV
Sound Problems with JVC AV-35BP4 TV
The audio output stage for the speakers may have failed in the TV set. If the set has an earphone jack, it is also possible that the jack has a fault (very rare, but I have seen this).
Are there external speaker outputs to try other speakers?
Jerry G.
Apr 29, 2008 | Televison & Video
Sylvania 6319CA 19 in. Combo Logo
51 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
