Question about GE GSS25SGMBS Side by Side Refrigerator
Gss25qswss front display panel shows 00 00 when I try to set the temperature. It is not letting me adjust the temp. Also there is no water in the dispenser. Thanks
  • 3 Answers
I was looking up another issue and found your problem. If the read out says 00 then it's in service mode. Unplug and plug it back in. You don't need to wait long. You can go to the GE site and download a PDF of the manual, but it's a joke for trouble shooting.
Posted on Jul 16, 2009
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Samsung rs2577sw Refrigerator
if you make the changes on the temp nob doesnt it work.
Jun 20, 2008 | Refrigerators
it sounds like you have a bad computer board in the back of the fridge,everything runs through the board.unplug it,remove the screws and cover,the board is held in with 4 plastic clips,you have to pinch in the plastic lock tabs with a needlenose plyers while pulling back on the corner of the board,pull it out,pull off one connector wire harness at a time,after you get a few off you can slide the new board into place and then finish switching the wire harnesses to the new board.hook up the ground wire to one of the screws on the frame,put on the cover and plug it in.also when you pull out the old board look at the back of it,sometimes you can see where it shorted out.when you look at the new board you'll notice that there's more relays on it,they upgraded the board and is much better than the old board.part number WR55X10942 and it's around 150 dollars.
Jun 05, 2011 | Refrigerators
The actual temperature (as measured by repairman's device) is 20 to 30 degrees lower than indicated on the control panel. Should the control panel be replaced in a 7 year old range or should the range be...
You can adjust the bake average temp +/- 35 degrees this is called calibration.
Here's How:
To Adjust: 1. Press the BAKE pad (upper or lower oven) and enter 550° F. 2. Press and hold the BAKE pad (upper or lower oven) for several seconds until TEMP ADJ is displayed. 3. Press the AUTO SET pad - each press changes the temperature by 5° F. The control will accept changes from -35° to +35° F. 4. If the oven was previously adjusted, the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F. 5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
Do this first and you will be back to normal. If your using a oven temp. checker make sure you let the oven cycle for awhile. Preheat should take about around 10min. Remember 350deg is an average temp.
Have a great day!
Dec 07, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Air temp indicator only reads temps below 50 degrees
Ambient air temp sensor could be the cause. Normally located in front grille area.
Oct 06, 2017 | 2002 Chevrolet TrailBlazer
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
GE GSS25SGMBS Side by Side Refrigerator Logo
292 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
