Question about Sony KP-46WT510 46" Rear Projection HDTV
Color Loss A Couple months ago our 3 1/2 year old TV firstly appeared to have a faded color hue. We tried resetting the color to default and nothing changed. Now a month later the color flips back and forth to full color to almost black and white and now it is just black and white. Are our bulbs gone? If so is this a fix we can do ourselves? What kind of info can you provide to help us with our problem?
  • 346 Answers
Replace tuner
Posted on Nov 24, 2007
Color and tint looks different. There is a green hue to the screen, and adjusting the tint and color does not help.
There is a problem with the connectors desoldering in the tv. My mother in laws tv did this after 2 months. Should be warranty issue if less than year old
May 10, 2010 | Insignia IS-LCDTV32 32 in. Television
My Sony KDF-E60A20 Grand Wega television has a color problem I am unable to resolve with the Sony remote. I have gone through the Wega Gate to settings...picture with no results. Running the hue and color...
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 05, 2017 | Televison & Video
The color on my mitsubishi model # vs-5041 is faded and foggy.
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
Hope this helps :)
Sep 16, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv, has yellow hue,lacks brite day and night
Replaced light engine. Be sure to note if model has an A at the end of it when ordering. They use different parts.
Aug 11, 2009 | Hitachi 51F59 51" HDTV Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Picture is fuzzy and color seems faded
Sounds like your coolant in the tubes need to be repalced. This is a common problem as the set gets older. Check with for the supplies and instruction guide.
Dec 09, 2008 | Philips 46PP9302 46" Rear Projection...
Color blinkig in and out.
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Jul 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Random turn off
just soldering your color ic or your RGB ic
Jun 20, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Color loss
Your formatter or what is called the FMT board has bad capacitors on it.
May 23, 2008 | Mitsubishi WD73727 73" HDTV
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
99 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
