Question about Garmin Edge 705 Handheld GPS Receiver
Cant delete gpx files from 705 edge memory. done all usuall stuff on pc, even tried deleting gpx folder but routes still appear in saved rides when unit re-powered up. any ideas anyone?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Only one idea ... Perform hard reset. Garmin devices have often data corruption issue, that can only be solved by return to factory settings :
Device powered off, press and hold mode and Power on buttons for 10 seconds, then pulse press lap/reset button.
You will be asked for confirmation, confirm, your device should be OK then.
Also update the firmware, you'll get last fixes for data corruption ... (does not mean there are none remaining ...)
Posted on Sep 25, 2010
I was trying to update my map on my nuvi 1350 and it said the internal memory was full. i tried to clear up some space and i ended up deleting some folders. I did back it all up, but now it won't let me...
The only files you should delete are unused voice files (.vpm), pictures files (.jpg), sum files (.sum) and you can delete the gupdate.gcd file as it is not used once the unit has been updated. You can also delete archived gpx files (.gpx) within the gpx archive folder but do not delete the current.gpx file (this file holds your favorites) or the gpx folder. Deleting folders is not recommended. That is a good way to delete files that you may need.
You can also right click on the Nuvi's drive letter and select "tools" and run an error check on the flash drive to make sure there aren't any errors on it that may involve how much space is really free.
Lastly, you may have to limit the map region, so that the map isn't too large. For example, instead of having US & Canada on the map, perhaps only have the US with the lower 49 states. You can limit it even further by selecting lower 49 states and selecting regions like Southwest (SW) or northwest (NW) etc.
f you really want to bypass the whole memory issue, just put the map on an external micro 4GB SD card. This way, you don't have to worry about deleting anything off of the flash drive.
I hope this info helps.
SHARCNET-USA
www.sharcnet-usa.com
Nov 30, 2013 | Garmin nuvi 1350 Car GPS Receiver
Garmin dakota 10 does not free up memory
Connect your dakota 10 to your computer ,double click on my computer or computer on deskstop and you will see garmin storage.And then double on garmin F .double click on garmin folder and if you want to delete gpx files click on gpx ,you can see current, archive and track log you've saved.Then you can delete tracklog you've saved .But some tracklog were automatically saved in archive folder ,double click folder and you can delete gpx file.In the same way if you double click on current folder you can see current gpx file and you can delete it.Like that you can delete image file in the same way.One important is you must not delete system files or folder.
Aug 20, 2013 | Garmin Dakota 10 Handheld GPS Receiver
Unable to delete the files from memory card
take out ur memory card from mobile slot, make unlock ur memorycard adapter. its on the side of it. and insert it and try deleting folder.
Oct 18, 2012 | Motorola Mobility ROKR E6 Smartphone
Hi... i have added one pik of my friend in folder 'my photos' (phone memory).., 4 making that picture as his caller id pik., now i have removed dat picture from caller id but when m deleting the...
Give this a try. Plug in your mobile phone to the pc. Once ask on how do you want to use it either sync,mass storage or com port just select mass storage. Once selected go to photos folder where the picture that you want to delete is located. Just drag the pic to a different location like c: drive or documents and try deleting the picture from there. Once the picture is removed it would not appear anymore on your contacts.
Mar 11, 2011 | Samsung Lands Phones
I've explored numerous option to delete specific folders/files from this unit unsuccessfully. When clicking delete the following text boxes appear simultaneously: Error Deleting Folder. File name, could...
Hi, what makes the files your trying to delete is not able to delete is, because the files your trying to delete has been affected by VIRUS and can be able to delete..
You will need to reset the Mp3 player .you can use the manual below for help
http://www.cobyusa.com/files/setupguide/MP705_SG.pdf
Have nice day..
Feb 17, 2011 | Coby MP-705 Digital Media Player
Thanks for the help in advance, i have two issues if u could plz help me with i have an acer aspire 5315 laptop with 80Gb memory. The thing is this memory is separated into two hard drives, C and D. 1)I...
Disk D is for storing recovery configurations. To see what happened to your memory, go to the root directory C: from your "My Computer" icon. Scroll to the folders in the root. Right click each folder and select "Properties." The drive will add up all the memory being used by that folder. Take notes on what you have and then drill down into the folders that seem to be using more space than they should be. Delete stuff you don't need. Let me know if you have more questions.
Dec 04, 2010 | Acer Aspire 5315 Notebook
Deleting songs
Connect the device to your computer. Click MY COMPUTER on your desktop. You should see the device in the window that opens. Click on it. It should appear as GPX Device or the like. Double click on that, then Portable Memory will appear, double click, then double click the Music folder. The window will now display all the music files on your device. Choose which ones you no longer want and hit the delete button on your keyboard.
May 31, 2010 | GPX ML648B MP3 Player
I cannot delete folders from my GPX they are apparently "Read Only" files...help!
You may try to delete your folders with Unlocker
If it doesn't you could try in dos (run cmd):
attrib -s -h -r "location" /s
(location being where the folder is located.)
This should remove any Systems file flag, read only flag or hidden file flag.
del /F "folders"
Jun 22, 2008 | GPX MW6347DT MP3 Player
K790i infetecd with virus help
you need to have the phone firmware reflash...take it to a mobile service center and have them reflash it for you.....or you can have it done online at www.topsony.com
Mar 09, 2008 | Sony Ericsson K790i Cellular Phone
Not working
If you have the manual in digital form, please post it on this site. Search the manual for a way to reset the device, if you can't find it try disconnecting it from any power source(AC, batteries, etc) for a few days. On showing Hidden files/folders: from windows explorer, while inside the GPX external drive- click on tools>folder options>view>hidden files and folders Good luck
Jan 05, 2006 | GPX M2104 MP3 Player
Garmin Edge 705 Handheld GPS Receiver Logo
348 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
