Question about Rockford Fosgate P3001 Car Audio Amplifier
Blown 40 fuse on amp
I have 2 12's with a rock foz p3001
there are (60) fuses under the hood and beside the bat capacittor
however,
everytime my car poweers on, my subs 'flare' and the fuse in thge amp blows.
  • e_phunk Jun 25, 2009
    sweet. good news. the amp powers on with out any subwoofer connection. the polarities are checked and good.
    i am worried that there is a short somewhere. and i dont know what that looks like or where to find it.
    the other thing is one sub is an almani dual sum.n and the other is a pioneer. prolly too much juice for one sub. the thing is they were woring fine together before.
    what is the next recomended step?
Jexx
  • 148 Answers
SOURCE: p3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Posted on Aug 17, 2006
SOURCE: smoke and no more juice
I Have also had this happen to me, pretty similar around the time it happened to you also, but I'm not just getting my hands dirty and inside the amp. If I fix this, I'll be sure to let you know what it was that I did, or bought and replaced......... I would also like some ideas and support on this if this has already been taken care of
Posted on Jun 10, 2007
  • 113 Answers
SOURCE: p10002 blown?
needs repair bad fets or outputs
Posted on Aug 09, 2007
  • 631 Answers
SOURCE: amp blowing fuses
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Posted on Nov 22, 2007
  • 91 Answers
SOURCE: im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Posted on May 06, 2009
Which fuse in the fuse box belongs to headlights in 2002 Ford Escape?
The fuse box is beside the battery under the hood. The fuses and what they relate to is marked under the lid of that fuse box. Use same size fuse if it needs replacing. If in doubt check all the 15 to 30 amp fuses.
Jun 07, 2014 | 2002 Ford Explorer
I have a 2000 Camry and the shiftr is stuck and have no power to radio, odometer, moon roof, Heater/AC, directionals, clock or break lights. Checked fuses all look good. There are 3 large fuses in the...
It could be one of the three large fuses under the dash, or it could be in the power distribution center under the hood. But it does sound as if a main fuse that feeds the smaller circuits has blown.
Sep 06, 2017 | 2000 Toyota Camry
Got new head gasket installed-not related to prob.after that bat.went dead,new bat and alt. still drains bat overnight. could it be a short in starter?
Check the main alternator fuse. It is either a block fuse in the fuse box under the hood or it is built into the positive battery terminal. If it is blown your battery will not charge even though everything else is in perfect working order and the alternator light(charge light) on the dash will not light up to tell you there is a problem. You will drive a short distance and the battery will go dead. After recharging it will start right up run OK till it runs out of juice again and dies, etc. Find the fuse and check it is not blown. It is a frustratingly simple fix to a hard to diagnose problem.
Aug 18, 2010 | 1998 Mitsubishi Eclipse
2003 Silverado Z71. Has had nothing wrong with it. Drove it fine all day. When I parked it and turned it off I thought I hear a pop sound, sorta like when a fuse blows..now there is nothing..it's...
Something is shorted, large amp fuses do not just blow. Go under the hood to the big black box marked FUSES. You are looking for the blown main ALT or BAT fuse, but you must find out why it has blown.
Make sure nothing has shorted out your positive battery cable, accessary wire, did you add anything to the electrical system that was not fused ?
Feb 04, 2010 | 2003 Chevrolet Silverado 1500
Which fuse is used for the ecu on a 2002 nissan sentra?
There are three fuses. If your vehicle is equipped with the QG18DE fuse 17 (10 amp fuse ) is located under the dash in the fuse box. And fuse 34 ( 15 amp fuse ) and fuse 36 ( 10 amp fuse ) are located under the hood.
If your vehicle is equipped with the QR25DE fuse 17 (40 amp fusible link ), 34 and 36 ( both are 15 amp fuses )are all located under the hood in the fuse box
Dec 05, 2009 | 2002 Nissan Sentra
I Have a 91 ford probe and The heater won't turn on I can't figure out why everytime I turn it on the fan don't come on and I'm not sure if it's the switch a fuse or the fan I can only find one fuse that...
The main fuse block located under the hood for the 1991 ford probe shows 13 fuses. There is a fuse that contros the heating, AC & Programmed ride control system. It is a 40 amp fuse and has a blue wire.the color code for a 40 amp fuse is green.
Sep 18, 2009 | 1991 Ford Probe
Jump wont work. 80 amp fuse blown under hood. where does fuse go
that is the alternator and vehicle power supply fuse, did u jump this wrong? u will need to replace this fuse before the car will start.
Mar 20, 2009 | 2001 Kia Sephia
Blowing of fuses
The reason your blowing fuses is the amp needs at the least a 150 amp fuse on the wire that runs to your bat. There are fuse blocks that you can put 4 40amp fuse and theres the high dollor ones that you can put all the way to 200amp. When you trun up your amp its drawing to much current for the little 40 amp fuse that you have and will blow it everytime. I recomend Running a 4 gage wire to bat and ground with same. Get you a 150 or above amp fuse from a car audio shop somewhere. anyway sounds like from what you decribed, theres nothing wrong with your amp just the wires and fuse are not big enouf to handle the current that your amp pulls.
Oct 21, 2008 | Lanzar OPTI 50c Car Audio Amplifier
Rockford Fosgate P3001 Car Audio Amplifier Logo
144 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
