Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
How to replace air filter on Troy-bilt TB20CS?
Troy-bilt TB20CS trimmer will start but won't run. Suspect air filter needs to be replace. How do I do that?
    Scholar:
  • 81 Answers
May be air filter but sounds more like your muffler is stopped up. First take the muffler off and see if it runs better without it. If so, burn the carbon out of the muffler and clean the muffler port on the engine. If not, then remove the four screw at the very end and disassemble. The ait filter is in that area. Diagram is located at
www.stollerlawnandgarden.com/.
Click on parts lookup in left hand column.
Posted on Jun 24, 2009
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Whats the gap on the spark plug on troy bilt tb20cs
Hello, Johnny -
The correct gap is .020" (0.5mm).
Link to specification page in owner's manual attached.
Troy Bilt TB20CS Operator Manual Specifications
Mar 06, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I have a troy bilt trimmer model tb20cs. has been laying for about four years. gave it a good cleaning ,new spark plug amd fresh gas. starts up fine and idles a short while then cuts off. If you try to...
Carburetor needs cleaning and probably diaphragms. Be sure to completely disassemble and pay very close attention as to where each diaphragm and gasket goes also make sure you remove the needle valve and clean screen.
Aug 25, 2017 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
My Troy-Bilt trimmer Model TB20CS will not start....I have replaced the primer bulb, hoses to the carb and to the gas tank...I have replaced the spark plug...My next step is to replace all of the current...
You have done and are doing exactly what is necessary to solve your problem.
Lastly: remove your carburetor and clean it thoroughly using carburetor cleaner available at most auto parts stores. Replace the diaphragm and metering diaphragm. Diaphragms become stiff with age and with modern fuels and will not pull enough of a fuel-charge into the combustion chamber.
Sep 26, 2010 | Troy Bilt 17 Inch 29 Cc Gas Powered...
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
1,437 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
