Question about IBM ThinkPad T40 2373 Notebook
IBM-T40 water on motherboard
Where can I send my T40 for repair, replacement of Motherboard?
  • KingCinna Jan 18, 2008
    I have the same laptop and also spilled water on mine. I didn't pull it open quick enough to save it in time. I just recently priced out the replacement parts and the motherboard/keyboard/hard drive run around $300. It's not worth the repair for me.
Call Rays Computers
Posted on Apr 11, 2008
  • 117 Answers
Ibm service ceter almost in all main places
Posted on Nov 06, 2007
I need to rest password in bios
Removing the RTC battery and leaving it uninstalled for 5 or more minutes causes all passwords and CMOS settings to be cleared. BIOS password can be removed by temporarily disconnecting/ removing the RTC/ CMOS (Coin-cell) battery from the motherboard.
Disconnect the coin-cell battery from the system board and it will reset the BIOS to its default setting and the password would be gone.
Please Refer to Page 29, 106 & 79 of the REPAIR MANUAL IBM T40 for Battery removal, keyboard removal and RTC battery removal instructions.
The Backup Battery (RTC, CMOS) is located under the keyboard. So you have to remove the keyboard to access the battery. The above Manual from IBM shows the exact method/ instructions and pictures for laptop dis-assembly for the purpose.
If you are comfortable with working inside such electronics, you can't do it yourself, or else you may seek help from local laptop service professional.
Hope it helps! Good Luck! Thanks for using Fixya!
Jun 21, 2011 | IBM ThinkPad T40 2373 Notebook
My ibm thinkpad t41 turns off after sometime when i turn it show cmos checksum bad
It is time to change the CMOS Battery Backup, its located inside the unit is the size of an nickle.
Dec 19, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
I have an IBM thinkpad T40 when I turned on the laptop the image doesn't appear and that times it would but then after a few seconds or minute the screen blanks out and won't appear again and sometimes...
There is no problem in your motherboard. In your motherboard, clean your ram and also where ram is put. Then restart your system again it will work. When it will not work please change your ram. Then it will work.
Nov 07, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
My IBM thinkpad turns off when i insert my usb internet connection into the usb slot and then wont turn on for a day or 2. What could this be?
It sounds like some sort of power drain or short on the motherboard. I recently made a repair job on a T41,casing on an IBM thinkpad T40 AND T41`S are very week.
My advice to you would be reinstall windows and see if it does it again,If it doesn`t then you will know for sure that it had something to do with windows.IF it still does after a clean installation of windows then its clearly a hardware fault.
*Hardware fault could be you`re power supply not giving enough juice(unlikely) *Motherboard faulty/Or Shorting somewere.If thats the case then a refurbished motherboard would do the trick.
Oct 18, 2010 | IBM ThinkPad T40 2373 Notebook
I need to know the part no. for the motherboard and the priceand where can I order the part. IBM T40 2374 thinkpad
Apr 02, 2010 | IBM ThinkPad T40 2374 Notebook
Laptop does not boot except when on AC, not a battery problem.
estas en lo correcto hazle revisdar el cmos y la ram que cuando estan por dañarse ocasionan alogunos problemas
Aug 24, 2009 | IBM ThinkPad T40 2373 Notebook
When i turn on my ibm thinkpad t40 a litle lock icon comes up an d re4cuires a pass word
The reason that comes up is because the motherboard has a master password set on it and from my experience the hard drive may have a password set on it as well cause the hard drive and motherboard are linked to each other.
If the original owner can call IBM then they can get both passwords removed. If not then both the motherboard and hard drive will need to be replaced.
May 19, 2009 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 PC Problem
usb ports are very simple decices, almost like a wall socket, they rarely fail, and if they do, it's generally a driver problem or the flat plastic pin inside the port has broken. Plus the usb ports are soldered to the board on these models. So, the usb failure you mentioned leads me to believe that that is another indicater that the board was going out. I'm a big fan of IBM, they are very durable machine. They can really take a beating. I cheched out Ebay and there are several T40 series motherboards up for bid. You should be able to get one at a decent price. Keep in mind that any of the T40 series boards will work for you.
Jun 21, 2008 | IBM ThinkPad T40 2373 Notebook
Thinkpad T40 2373 fan replacement: long or short?
s.gif s.gif s.gif s.gif s.gif Item Specifics - Item Condition
Condition: Used
s.gif s.gif IBM THINKPAD T40 T41 T42 CPU Short Cooling Fan FRU 91P9759 91P8393 this is the fan you need. please remember to rate the solution. will send you a link to my site with the how to disassemble and reassemble
Apr 09, 2008 | IBM ThinkPad T40 2373 Notebook
Motherboar dproblem
The CMOS battery & jumper will be placed below the touchpad buttons to view these you need to open entire laptop.
please open this part if you are good in laptop trounble shooting.
or else you can log a complaint to IBM support 1800-425-6666 (india) they will take care.
if u did some small mistalk laptop will not boot
Nov 30, 2007 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
369 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
