Question about RIM BlackBerry Storm 9530 Smartphone
Blackberry Storm: My Menu button and end button do not work
When I click the menu button or the end button nothing happens. The grean call button and the escape button still work though and so does the touch screen. I did not drop it or anything. The battery was dying so I charged it, and while it was charging I tried using it and found those two buttons did not work. I removed that battery twice, but it did not fix the problem.
    Problem Solver:
  • 6 Answers
This problem happened to me and I just figured out the answer. If you recently installed a new application or a new theme then it will probably mess with your button configurations. Remove the theme/application you installed just before the problem started happening. Once you removed the theme/application convert back to the default theme and your buttons should work again.
Posted on Jul 01, 2009
Free MEP code for blackberry storm 9530
Are you asking a MEP code for unlocking your Blackberry 9530? If so you can get the accurate unlock code from www.unlocking4u.com/blackberry-9530/rs6wp9/ at affordable cost. Here are the steps for unlocking a Blackberry 9530:
- Switch ON your Blackberry 9530 phone with Not Accepted SIM Card.
2 - Click on Turn All Connections Off.
3 - Press Back button to go Back one Step.
4 - Go to Options.
5 - Select SIM Card.
6 - Press the Menu Key and select Show Keyboard.
7 - Tilt the phone in Horizontal Position so that the Keyboard is displayed in the Landscape Mode.
8 - Type MEPD (letters will not appear on-screen but a menu will pop up).
9 - Type MEP2 (user will be prompted to enter MEP code).
10 - Enter the unlock code.
11 - The Blackberry 9530 phone would then display the message 'Code Accepted' and unlocked successfully!
12 - Go back to the Home Screen. Press the Menu Button and click on Manage Connections.
13 - Click on Turn All Connections On.
14 - The phone will now reboot and 'Activation Required' will no longer be displayed
Sep 11, 2012 | RIM BlackBerry Storm 9530 Smartphone
My blackberry storm's red and menu buttons don't work
Install Blackberry desktop Manager ...Take Backup..
Reinstall the Software ....
if not happening contact service center as there might be any hardware problem.
Aug 13, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cant find the browser on my 9530 storm!!!!
Are you able to receive emails on your device? Do you see a 1xev, 1XEV, or 1X?
There are a few places you can look if you are able to get email.
First, Click the Blackberry menu button so you can see all your icons.
If you dont see the Browser Icon on this list, it may have been moved to another folder, or hidden.
If hidden please follow the steps below:
-Press the blacberry menu button
-Select Show all
-Locate the greyed out icon that says Browser
-Highlight it, dont open it, select the blackberry menu button
-Select Hide, this will take off the check next to Hide.
-Select the Blackberry menu button
-Select Show All - this will rehide the hidden icons
If in another folder:
-Choose the folder
-Repeat steps above until you find the Browser Icon
Chances are it might have accidently been hidden or moved to a folder.
Jul 23, 2009 | RIM BlackBerry Storm 9530 Smartphone
Only 15 hours of stand by mode battery run out
Make sure there is nothing else running. Press and hold the Blackberry menu button. Then it will show the applications running. Make sure its just the normal ones. Also what do you having running in the background that might now show up on the app list. For example, Facebook, myspace, twitter, etc. all these communicate back to the server taking up valuable battery life.
I use my Storm a lot for business and end up charging it every night. I have the original Storm from when they came out and the battery seems to last ok.
Jun 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm buttons wont work
Have you tried pulling the battery? Often times my Storm has locked up and nothing worked. The only way to really do a restart, is by pulling the battery.
-Take the battery out and wait 1 minute. -Replace the blackberry and wait for Operating System to startup -Test
If this doesnt fix the problem, you may have a problem unit and you should take it in to the Verizon Wireless store.
Jun 20, 2009 | RIM BlackBerry Storm 9530 Smartphone
My blackberry storm won't log calls expect missed calls.
Go to your call log.
Press the BlackBerry menu button.
Scroll to "Options" and click on it.
Click on "Call Logging".
Click on the logging option you would like.
Press the menu button and save your selection.
I hope this helps!
-Jason
Jun 13, 2009 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm 9530 not logging calls
I hope this helps!
-Jason
Jun 11, 2009 | RIM BlackBerry Storm 9530 Smartphone
My Send & Escape buttons wont work on my Blackberry Storm
Try taking the battery out for about 30 seconds then turning it back on. If that doesn't work, try running on air programming if that is available to you. Check with your customer service for that.
When click bb button my options buttom doesn work
If you are at the home screen and the phone is unlocked, press the "blackberry" key, next to the green answer button. The on screen menu should show "options". If you click on this, nothing happens? If it does pop up with the next window, the row adjustments are in the middle of this screen under "Set Homescreen Layout". Once you have selected this, be sure to press the blackberry button again and save your selection.
Hope this helps!
May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
3,732 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
