Question about LG Heating & Cooling
Lg split system air con model ls-J0962hl the problem is when you put it on the sun icon it turns off and the green light on thr system lights up on fan water droplet icon how can I get heat out of it please
Found the manual
Posted on Jun 24, 2009
Air-Con Mini split --gives error code 4 shuts down after 25 minutes
Hi Emanuel,
Your out door unit could be very dirty or the outdoor unit temperature sensor is out of position.
May 04, 2014 | LG LS-K1830CL Cool Mini Split Air...
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
Split system air con LG model LST 2434C-2 unit won't turn on, remote is working but unit won't respond, turned on at wall.
Check there will be red icon when power is on,before switch on by emote. If no red light, there is no power goes into indoor unit. Check. If red light is there and no response with remote, communication error between remote and PCB in indoor. Try with other same type remote. If yes, replace battery or replace your remote. If no, receiving sensor in PCB problem. Repair or replace it.
Jan 13, 2011 | LG Heating & Cooling
What is the button to heat up my room?
Open the cover on the remote, to the top left (usually) there is a single button which if pressed repeatedly, changes the mode settings. This can also be seen by changing icons on the display. The first is an ice crystal, second tear drop, third a triangle with a moon, fourth is a sun. Press until you have the sun icon in the display area. Then close the remote and using the up arrow and down arrow buttons select the temperature which is comfortable for you.
Nov 17, 2009 | LG LS-L1210CL Mini Split Air Conditioner
I have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Jun 11, 2009 | Sanyo Split System Air Conditioner
My mini split does not run
Check that you are on the correct mode setting. Open the remote and press the mode button (the one with about four little icons, star, teardrop, triangle and sun) until you get to the mode you require. If cooling required, select the star or crystal, if heating required select the sun (circle with little lines)
Mar 06, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Cant turn air con of with control
if the remote is lg it haven't code the eye of the plate has burned
Feb 21, 2009 | LG LS-L1210CL Mini Split Air Conditioner
No heat
Please make sure that the correct mode setting has been selected. Depending on model you will see the mode button has four little icons. A star/crystal, a teardrop, a sun (circle with lines out going) and a sort of triangle. You press this button until the correct icon appears on the display, it should be the sun icon.
Aug 07, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
304 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
