Question about Cat5e Cat 5E Modular Plugs - For Round Stranded Cable - RJ45 Mod Plugs (301178)
Cat5e to RJ11
I have purchased a small PABX system, it arrived with RJ11 ports to connect my telephone extensions to, my extensions are wired in Cat5e cable. Can you explain how to to connect the cat5e cable to the RJ11 plug connectors?
  • 306 Answers
Re: Cat5e to RJ11
You wont be able to....You need another can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Posted on Nov 10, 2007
0 characters
3 Points
Cat 5 cable
The normal color code is. Orange white, orange, green white, blue, blue white, green, gray white, gray. the wire using for network only 2 pair. That is 1,2,3,6. For normal telephone - use blue pair (4,5). For pabx system use. 3,4,5,6. Connection. You can use any Color code If both ends are same.
Jul 02, 2012 | Network Accessories
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Network Accessories
I need to wire a network cable into a wall plate purchased at home depot. the plug is not rj45 but a block with 8 screws and different colored wires. the problem is the colors don't match cat5e wire.any...
I have tried this, and my suggestion is to go back and get the proper wall jack. How much are headaches worth to you? If they are worth more than the wall plate, just **** it up and get the correct one.
Jan 05, 2010 | Cat5e Network Accessories
Network & Telephone Cabling
Sure you can,
But.... what are you going to use it for? if to connect 1pc to another there will be no connection, as for a telephone line only have 4 lines and the RJ45 connection to PC uses 8
Apr 03, 2009 | PC Connection RJ45 Connector
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
Dont know how to hook up cat5e cable to a leviton cat5e jack
Those two jacks are telephone jacks (RJ-11) not ethernet (RJ-45). The jack marked telephone is for a phone, and the jack with a rectangle symbol is for the telephone line into the wall.
You need to buy an ethernet PCI card - without one you can not use a cat5e line (which has an RJ45 connection).
Nov 22, 2008 | Leviton Network Accessories
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Connecting Cat5e cable to BT 78A junction box
You can get this device to help you.
I believe it is on the 8th page.
Oct 08, 2008 | Network Accessories
The max distance that Cat5e or Cat6 can be run is 90 meters or 295 feet. As cnavarro stated, signal repeaters would be best utilized in your situation up to 590 feet otherwise fiberoptics are the next and more expensive route. You should also divide the run equally with the repeater as it would not be effective with an offset balance.
Sep 14, 2008 | Cat5e 100 Foot Shielded STP 350mhz Network...
Network connection
Hi roamer, It seems you are using dial up connection at home that is through telephone line. In hotel you are using broadband or any other connection. For both pathch cables and their connectors are different. One is RJ45 other is RJ11. You can identify yourself by checking cable patching.
Sep 04, 2007 | Ortronics 110C Connecting Blocks - 4...
Network Accessories Logo
429 people viewed this question
Top Cat5e Network Accessories Experts
Brian Sullivan
Brian Sullivan
Are you a Cat5e Network Accessory Expert? Answer questions, earn points and help others
