Computers & Internet Logo
A
Anonymous Posted on Jan 16, 2018
My laptop mouse pad not working properly?
My hp laptop's musepad/touchpad is not working since some days.. When i use it it starts running here and there and when i connected an external mouse it worked some days ago but has stopped working now...When i connect it a message is shown saying Usb device not recognised.Mouse is also not working
Bill Boyd
Level 3:
Top Expert:
  • Computers & ... Master 53,816 Answers
  • Posted on Jan 16, 2018
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925790
Points
172802
If you are running win 7 uninstal the driver for the mouse the get it from the web page for the manufacturer of the mouse
Download the driver for win 7
5 Related Answers
jessee007
JP Services
  • 310 Answers
  • Posted on Jan 16, 2008
SOURCE: touch pad
in order to get the setting correct you need to unplug your usb mouse
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Anonymous
  • 2028 Answers
  • Posted on Aug 28, 2008
SOURCE: Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Anonymous
  • 92 Answers
  • Posted on May 27, 2009
SOURCE: lenovo touch pad not working properly
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
Anonymous
  • 145 Answers
  • Posted on May 29, 2009
SOURCE: keyboard and mouse inoperative
check all at bios, maybe it is not well configured and try to update your USB driver, maybe it is not supported version
Anonymous
  • 197 Answers
  • Posted on Jul 01, 2009
SOURCE: mouse pad not working - external mouse works fine,
try to re-intall your mouse pad driver and update your machine's bios.
if still doesn't work then you mouse is faulty and might need to replace.
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
1helpful
Hp 630 touchpad not working -pointer moves but doesn't click
Double click on pad surface. Buttons could be faulty. Check mousepad settings. Install drivers
My mouse pad in my computer wont work when i tap it
It will depend on what touch pad (and related software) is installed on the particular computer, but you will find the tap option under the Control Panel. Open your control panel, select "Mouse" There will be a TAB in the mouse properties called "touchpad" (surprise, surprise!) where you can toggle tapping on/off.
Hope this helps. PS: if you DONT see the touchpad option - you will first need to install the drivers/software for your touchpad. Most HP touchpads are the Synaptics Touch Pads - Find the drivers here: --> Click here!
My touchpad is not working but when I connect an external mouse t the USB, it works properly. Pls help.
1. check is there any botton just above the touchpad.
2. if there is a key then press once & it will start working
3. else update the drive of the touch pad.
4. if not working the take it to a service centre for replacement.
I am having HP laptop. For last 2 days my touchpad
try reinstalling the driver for the mouse pad
that should go fine
1helpful
3answers
Turned on my v2000 and the mouse pad is dead, wireless mouse works fine,
try reinstalling driver for touch pad. also do registry check sometime your registry gets scrambled and you lose devices as a result. run a registry program first. u can get one at www.majorgeeks.com for free. if that doesn't fix ya up reinstall the driver for the tft pad or mouse pad as u called it
4helpful
2answers
Lenovo touch pad not working properly
Hp laptop touchpad mouse problems
IF U HAVE REPLACED THE DRIVERS TO THE MOUSE DEVICE THIS INCLUDES ALL THE PROGRAMS THAT THE SITE HAS TO RUN THEM. THEN ITS A HARDWARE PROBLE IN WHICH THE ACTUAL CONTROL FOR THE MOUSE CAN BE REPLACED.
2helpful
2answers
My sony laptop touchpad not working properly
i have two solutions for you. the touch pad can be disabled on the motherboard so plz hold-down the fn key and press the function key that has the sign of a hand pointing something and the second is that ur drivers that enables thae touch pad to work has been courrupted so plz try reinstalling for the touchpad or try repairing ur operating system.
98helpful
9answers
Scrolling button on touchpad not working?
SCROLL PAD SOLUTION THAT WORKED FOR ME!!!
Well what I did was I went to CONTROL PANEL, went to the HARDWARE AND DEVICES, went to the DEVICE MANAGER which has a list of Devices. I found the MOUSE DEVICE on the list, right clicked it went to PROPERTIES go to the DRIVER TAB, and then click on ROLL BACK DRIVER. Restart your computer. and then repeat everything again. CONTROL PANEL>DEVICES>MOUSE>PROPERTIES>DRIVER TAB when u get back to the driver tab of your mouse device. click on UPDATE DRIVER. It will then find the driver automatically reinstall it for you and then restart your computer. HOPE this fixes your scroll pad. It did for me.
Grand Canyon Tech
Grand Canyon Tech
