Question about Leviton 878RTD0110W Do it Best Fan and Light Control
The switch does not control the speed of the fan.
The switch does not control the spped of the fan. fan only works when switch in the max position does not work tha max min lo. help
  • 76 Answers
I WOULD THINK THAT THE POWER SUPPLY FOR THE FAN IS WIRED BACKWARDS ANDTHAT WOULD EXPLAIN YOUR PROBLEM SWITCH THE FAN WIRES ONLY! ! ITHINK YOUR HOT IS GOING INTO THE FANS NUETRAL
Posted on Jun 24, 2009
2002 heater gauge only works on high
Heater gauge or fan spped control? If you mean fan speed control, then it needs a new resistor pack. And it is usually located in the heater duct works.
Oct 22, 2012 | 2002 Dodge Intrepid
Vw polo heater blower only works on full power
all speeds go through the resistor except high that is why it will work on high you are bypassing the resistor if you are sure the resistor is good it has to be the blower spped switch on the dash
Sep 24, 2012 | 2004 Volkswagen Polo 1.4
2002 mazda mpv air conditioner fan control module problem?
Check and replace fan switch control module located in glove box...$30. part. Do it yourself.
Oct 20, 2017 | 2002 Mazda MPV
Hi Everyone. Quick question.. I have 1999 Plymouth Voyager. And for some reason my control switch to the ac won't work on low. It has 4 speeds. It works only on full blast. Im new to this. I just want...
I think you are referring the fan control switch. Normally the fan has to work before the AC will turn on.
So if the ac is working only on higher spped settings, you need to confirm if the fan is actually working at the low settings.
Jul 27, 2011 | 1999 Plymouth Voyager
Hunter fan with pull switch - has high spped and low speed but no medium. How do I fix this?
Try replacing the pull switch which is located under light attachment on bottom of fan. If no light it is under cap located on bottom of fan. You can purchase this switch at Lowes or WalMart.
Aug 27, 2010 | Hunter Ceiling Fan Control Switch
Inside Fan Relay location
replace blower motor switch on dash
Dec 18, 2008 | 1998 GMC Sierra
Wiring p fan speed cotrol switch
most common fanlight control is 2 dimmer switches in parallel to control fan spped and light, direction is still usually controlled on the fan body
requires 3 wire in the light box, and a compund dimmer, this one has left and right and fits a single switch box
where a fanlight is used to replace a regular household fitting there is often only 2 wire in the switch box, either a sparky can fishtape an extra cable along the lamp cable, or replace the wire,
the 3 wires from the fanlight are light fan and neutral
some new retrofit fanlights have remote controls to negate rewiring
Apr 26, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Leviton 878RTD0110W Do it Best Fan and Light Control Logo
127 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
