Question about Canon PIXMA MP600 all-In-One InkJet Printer
No paper message
My fairly new - about six weeks psc has suddenly developed a dramatic graunching noise and an out of paper message, even though there is plenty of paper in the tray. What should I do ?
  • lour Nov 13, 2007
I have just posted a very similar problem!!
While I do not have the solution to our problem, I discovered another paper try below where the printed paper comes out.
Close the door to block where the paper would come out if it successfully printed, and look below that, you will find that you can pull out another paper tray. Adjust the little plastic paper guides inside, and your printer will use that paper.
Temporary solution, let me know if you figured out how to fix the problem with it rolling the paper through, just reply/post back to this message. Mine was working perfectly yesterday, and just started that grinding noise today. I've only had it for a couple months, too.
Posted on Dec 05, 2007
  • Linda
    Linda Dec 05, 2007
    Here is what fixed my problem!! It took one minute to fix, printer fixes itself - Good luck! See below:
    It turns out that I needed to clean the roller (I searched around on the Canon's help site)
    To check out the link for yourself: Clean the Roller
    Here are the steps:
    Paper does not feed through printer
    Clean The Paper Feed Rollers Using The Operation Panel - MP600
    Clean The Paper Feed Rollers Using The Unit's Operation Panel
    the paper feed roller is dirty, paper is not fed properly because the
    paper feed roller slips. Cleaning the paper feed roller could resolve
    the paper feeding problem. Please follow the instructions below to
    clean the Paper Feed Rollers directly from the unit.
    Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
    1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
    2. Use the button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
    3. Press the (A) button.
    4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the button.
    5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press .
    6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press .
    7. Use the up / down cursor button to select [Yes], then press the button. (The paper feed roller cleaning starts.)
    8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
    9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press .
    10. Use the up / down cursor button to select [Yes], then press the button. (Paper will be fed.)
      Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
    Paper Source
    Press the button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the is set for that paper source.
    The above illustration shows a PIXMA MP500
    Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source
    setting in the printer driver. If the option is not set to 'Paper Feed
    Switch', paper will feed from the source selected in the driver.
Hi, on my JB5538 Wristech, even with brand new batteries, the unit never seems to inflate ! It developed this problem about 3 months ago out of the blue. Keep getting Err message. How do I fix it ? Th
either the compressor unit seals are damaged or you have a hole in the inflatable section either way it is not an easy fix and as they have come down in price dramatically over the past year i would suggest buying a new model & chucking this one away
Nov 12, 2014 | Health & Beauty
Fax machine will not draw the document that is to be faxed into the machine - there is a loud graunching noise (which doesn't sound just as if the rollers aren't going round properly). If I push the paper...
Sounds like there was a paper jam and the paper was removed with force damaging the mechanism.
You will have to take a look by taking it to pieces and replace the damaged cogs.
Nov 09, 2017 | Brother FAX-8070P Plain Paper Laser
I installed a refilled HP 94 cartridge in my HP PSC 2355 All-in-One printer. It worked well for several weeks but then I suddenly got the following Error Messages: "Incorrect Cartridge - Black ink...
This is a firmware issue with this printer model, and is fairly common. Try the following: remove both of the print cartridges, close the lid, wait for any noises to stop, and pull the power plug out of the back of the printer while it is still on. Wait at least 10 minutes with the cord disconnected. Plug the power back into the printer, wait for the noises to stop, and then reinstall the cartridges, black first (very important), and then the color. This will force the printer to reload its ram memory and should take care of the glitch. Let me know if you need further assistance, as I would like to be sure your problem is fixed.
Sep 30, 2010 | HP PSC 2355 All-In-One InkJet Printer
Bad smell from rear of refrigerator
Pour some bleach full strength in the pan.
May 15, 2017 | Refrigerators
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Grinding Noise and no printing
grinding is NOT cool...i'd say that you have a mechanism issue with this printer. How long have you know this printer?
Mar 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Out of Paper. Load Paper Error
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
131 people viewed this question
old marine
old marine
