Question about Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera has flashing channel info in upper left corner
When my panasonic viera turns on, the channel information in the upper left hand corner keeps flashing and there is no picture. I think it could be a problem with overheating.
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Posted on Jun 24, 2009
Turn on the TV, red light stays on, picture goes blank after a second.
I have the same problem. Factory reset did not help (hold Vol-minus on set and menu on remote five seconds, then unplug). Can there be something in service mode that would help?
Aug 04, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Someone apparently has been messing with the remote control. The TV seems to be stuck in a mode. When the power is turned on, the TV shows a blue flashing channel indication (9-2) in the upper left hand...
Hello and yes there is a easy way to solve this issue, on your Panasonic remote go to options or menu, in your memory list there should be a selection called either factory reset or default settings, choose it and hit OK, this will set your tv back to its original out of the box state.
Jun 24, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Just bought panasonic th-42x20k, when turn on hear a clicking sound and then turn off, red light under screen flashing 7 times
Red light flashing indicates that "SC voltage is floating". I'd recommend replacing the SC, SD and SU boards. Also know as the Y sustain (SC), Upper and lower buffer boards (SD, SU).
I suggest you contact your local Panasonic Service Agent as parts are only available from Panasonic and are quite expensive.
Jan 18, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I can't find the jump button on my panasonic remote control. Is there such a button on the remote control which can jjump between two channel?
Should be a button on the bottom left of the remote labeled R-TUNE. That will send you to the last previously viewed channel.
Dec 24, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Oct 30, 2007 | Sony KLV-S23A10 23 in. LCD HDTV
Panasonic viera 37"
I solved it switching on and off the satellite cabled on scart 1, it was like it sent some strange bits of activity, even though being turned off
Sep 27, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TH-50PZ80U Plasma TV Logo
947 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
