Question about Electrolux EL7055A Bagless Canister Vacuum
Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
I loved this vacuum when I first got it in July but it has very weak suction now. I have checked the hose and cleaned the filters. Doesn't appear to have any blockage. Any ideas? Too expensive to have it be so worthless!
  • BGH77 Nov 12, 2007
    Worked great at the start, now it's suction level is low and every now and then it just stops suggesting it's blocked but can't find anything wrong. It starts working after awhile with no reason for the change.
  • 75 Answers
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Posted on Jan 28, 2008
I had the exact problem. Here's what I did and it now works fine.
1) Remove and empty the dust container.
2) Remove the cover on the side of the dust container of the round space by pulling it straight out.
Mine was totally clogged. I just need to remember to do that periodically.
Hope this helps.
Posted on May 26, 2008
Electrolux vacuum has very little suction
If you have dogs that shed, canister vacuums will always need cleaning out.. try to empty it before it's total full more often, this should prevent it from backing up so much.
Sep 03, 2015 | Electrolux Access T8 Bagless Canister...
Remote control Electrolux flashes 3
Can you give more information...what model and what is happen.
Aug 23, 2013 | Electrolux UltraActive EL4300A Bagless...
Suction weak, vacuum seal spring is releases
I would recommend checking the dyson vacuum brushroll first. If there is any hair or thread wrapped around it you are going to want to cut all of that free that way your brushroll can spin freely. I would also recommend checking the filter and washing or replacing that. On the DC 14 that is going to be on the top of the dust canister as well as under the canister if you lift it off of the unit.
Dyson vacuum repair Highlands Ranch
Jul 17, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Electrolux EL8505 does not have suction. Hoses have been checked. No warning lights on. Help
I had the same problem I found a clog in the hose between the beater brush and the canister. I used compressed air to unclog.
Apr 27, 2011 | Electrolux EL8502 Versatility Bagless...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Weak suction on dyson dc05. The suction is not as good as usual
Hi its Darran at Dyson.
Try washing your pre filter and checking the machine through for a blockage. These are the most likely causes.
A full blockage procedure and filter washing instructions can be found at www.dyson.co.uk/support.
Kind regards
Darran
Dyson Customer Service
Feb 16, 2010 | Dyson DC05 Bagless Canister Cyclonic...
My vacuum tools have very weak suction.
There is a foam ring filter in the bottom of the canister that collects the dirt. It screws off of the bottom on the canister. Take outside and shake it out. It fixed our suction problem.
Jan 31, 2010 | Bissell 3576 CleanView II Bagless Upright...
Suction
absolutely all the air in a vacuum would pass through the filter and if its clogged badly you could loose all your suction and if the belt is more than a year old then replace it even if it isnt broken ( they stretch out over time )
Sep 17, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Electrolux EL7055A Bagless Canister Vacuum Logo
612 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
