Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
How do you program in the frequency
Dont have a manual cant seem to make it work
    President:
  • 2,761 Answers
There is no programming on this radio. With power and an antenna connected, turn the power on and you should see a channel number in the display. Turn the volume up about 1/4 of the way, and turn the squelch down. You should hear either transmissions or noise. If all you get is silence, the receiver section is "fried." If the unit does not power up at all (no lights/displays at all) then you most likely have a blown fuse - a simple fix.
Posted on Aug 29, 2009
I cant seem to be able to program a frequencies into my scanner. I have a list of local frequencies but the numbers are to large to enter into the scanner to accept. it only holds up to six numbers but...
Frequencies in the range you mention may be part of a trunked system that your scanner cannot follow, but you can still enter and monitor the frequency. Yes, your BC340CRS will handle frequencies with up to five decimal places, as long as the last two digits are 25, 50, 0r 75 (see page 16 of the BC340CRS Owner's Manual). The best programming instructions for your scanner are also in that manual. If you don't have a copy, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Mar 01, 2011 | Uniden BC340CRS Base Scanner
I HAVE A UNIDEN BC80XL HAED HELD SCANER RADIO. MAYBE IM STIPID BUT I CANT GET IT PROGRAMED FOR ANY FREQ. i NEED SOME REALL HELP THANKS
Your first step is to compile a list of active frequencies in your area. You can find a very good database at:
Next, mark or highlight the frequencies that you want to program, making sure that they will work with your scanner. See your scanner manual for a list of covered frequency ranges. The BC80XLT will hold 50 frequencies.
Once you have the desired frequencies, you're ready to begin:
- Power the scanner ON.
- Press the MANUAL key.
- Enter the channel number that you want to program (01 - 50). If you're going to program the entire scanner for the first time, start with channel 01.
- Use the keypad to enter the desired frequency, including the decimal point (e.g., 146.075). Zeros at the end of the listed frequency need not be entered (e.g., 805.25000 should be entered as 805.25).
- Press the E key to save your program information.
- Press MANUAL to advance to the next channel, then start by entering the frequency.
More detailed instructions are in the factory manual. If you don't have a copy you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC80XLTom.pdf
Bill B.
Feb 08, 2011 | Uniden BC60XLT-1 Handheld Scanner
Im trying to program my Pro-70 Hyperscaner
To program a known frequency into your PRO-70:
- Press PGM. PGM appears on the display, indicating that the scanner is in programming mode.
- Enter the number of the channel that you wish to program (1 - 50), then press PGM again. As an alternative, press PGM repeatedly until the desired channel number appears on the display.
- Enter the desired frequency, including the decimal (for example, 156.045).
- Press E/L-OUT to store the frequency.
- Repeat steps 2 - 4 to program another frequency.
Your scanner's operating manual has details on other programming steps. If needed, you can download/print the manual here:
http://support.radioshack.com/support_electronics/doc62/62177.pdf
Bill B
Apr 23, 2010 | Radio Shack Pro-97 Handheld Scanner
Cant seem to get it to pick up local frequencies
Can't really diagnose the problem without more information, but make sure that your antenna is connected properly and that you've programmed frequencies that are active in your area. For a quick function check, program the frequency 162.55, 162.4, 162.475, 162.425, 162.45, 162.5, 162.525, 161.65, 161.775, or 163.275 into your scanner. One of them, probably the first one, will be the primary weather frequency in your area. If the scanner picks up the weather broadcast you'll know that it's working.
Dec 28, 2009 | Uniden BCT8 Base Scanner
Cannot for the life of me figure out how to program this!
You need to obtain local frequency numbers for your area.
google search, "radio frequencies" and you county, city name...it'll give you lists of frequencies to enter into your scanner..
Your user manual should show you the step by step with which buttons to push... are you having difficulty entering the frequency numbers?
k
Jul 06, 2009 | Uniden BC60XLT Handheld Scanner
I dont no how to program my regency z30 scanner
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you wish to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Apr 07, 2009 | Office Equipment & Supplies
How do I Program my Uniden Bearcat BC60XLT
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Aug 09, 2008 | Uniden BC60XLT-1 Handheld Scanner
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Radio shack pro-97 hand held scanner
you can go to scanner master.com and get what frequencys you need. if this don't work let me know i will give you a new site.
Oct 31, 2007 | Icom IC-R5 Handheld Scanner
Programing
Here is a pdf format copy of the BC278CLT manual
http://www.uniden.com/pdf/BC278CLTom.pdf
Page 12 to program scanner frequencies.
Rollin CBs
Dean
Sep 30, 2007 | Uniden BC278CLT Base Scanner
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
110 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
