Question about MegaVision MV173 (Black) 17 in. Flat Panel LCD Monitor
Megavision MV173V & MV173-0
I have 2 of the mv173v's and 1 mv173-0. the 173v's have what they say is version '2'. and the 173-0 has version 1.03. is there a way i can upgrade the 1.03 version to the 2.0 version? Also, i've searched for drivers and i don't find any for Vista 32bit and 64bit.
any help would be much appreciated.
thanx
Gary
Tip
I have a megavision 19" flatscreen monitor. The color is all screwed up. It has...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Feb 13, 2008 | Sony SDM-HS73P 17" LCD Monitor
How to upgrade megavision 500Gb karaoke player?
Can anyone please help me.. may megavision ako, I connect it to my sony tv and sony home theatet system pero pag kumanta ako may delays sa voice ko.ano po pwede ko gawin para mawala yun please helppp...
Feb 15, 2014 | Audio Players & Recorders
Where can I find a Megavision MV173 LCA01F "monitor to computer" connection cord?
Isn't it a VGA cable?(15 pins-3 rows of 5 pins,slightly staggered.There is a 15 pin D-sub connector(2 rows of pins)-usually for extending a joystick cord on a PC.
Dec 16, 2012 | MegaVision MV173 (Black) 17 in. Flat Panel...
Megavision mic echo not eorking
Mic element open
not connected correctly to plug
battery bad or broken connection
defect in mic amp board or echo circuit
Apr 10, 2012 | Radio Communications
The monitor goes dark within a few seconds of turning it on. Is this something that can be fixed or do I need to replace?
Try replacing the power cable. (assuming that the monitor has not lights when it turns off) After replacing the power cable if that doesnt work try a different outlet.
If there are lights try seeing if you can replace the data cable from the monitor to the computer. If that doesnt work then you will want to look into getting a replacement.
Mar 01, 2011 | MegaVision Hyvision Megavision 191 19"...
Power supply bad
Hi there.
have you tried changing the power cord you are using?
Nov 28, 2010 | MegaVision Hyvision Megavision 191 19"...
My monitor has a blue cast over everything!
Check all the pins at both ends of the cable and make sure they are seated properly, also try it with another PC to make sure it is not the PC video card problem.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 29, 2010 | MegaVision Hyvision Megavision 191 19"...
Megavision - Why does it only allow you 57 minutes of a movie?
A lot of companies do this. It's because the cost of bandwidth is expensive. They cap you at 57 minutes, usually for a length of time, then allow you to watch their content again.
These type of companies usually have a subscription fee so that you can watch whatever you want for a specific amount of days.
Other than that, you can attempt to use a proxy or use an IP Changer software application.
Apr 21, 2010 | Microsoft Windows Vista Home Premium with...
MegaVision MV173 (Black) 17 in. Flat Panel LCD Monitor Logo
80 people viewed this question
Top MegaVision Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a MegaVision Computer and Internet Expert? Answer questions, earn points and help others
