Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
My heater is a natural gas, it will start fine run for abouy 5 mins then service heater light comes on for a min or less then it starts up again,we changed the thermal regulator,still nothing any idea what is causing it to cut out
Did you check the diagnostic LEDs under the Control board enclosure? I had the same symptom. The HLS diagnostic LED was illuminated so I first replaced the High Limit Swich which did not fix the problem. I should have known the switch was working ok because the water that was comming into the pool was way too hot so the HLS was just doing its job. The next thing to replace was the Thermal Regulator which was corroded. Probably because of my salt chlorination system. This fixed my problem. Since replacing the Thermal regulator did not fix your problem I would check the return water and see if it is abnormally hot during the short time when the heater does run. If it is not, then your high Limit switch may be bad. If the water is hotter than normal it is probably your Internal Bypass Valve (Manifold Bypass Valve).
Posted on Jul 29, 2009
  • 139 Answers
Sounds like a bad or dirty flame sensor
Posted on Jun 25, 2009
My pump pressure will not adjust down...no matter how much I back out the screw....What could be my problem
WHAT TYPE OF HEATER BRAND & MODEL#? ARE YOU CHECKING INLET OR OUTLET PRESSURE AT GAS VALVE? IF IT CALLS FOR 3.4LBS. IT'S A NATURAL GAS UNIT CORRECT?
Dec 24, 2012 | Heating & Cooling
I have a laars lite 2 manual controls natural gas. The unit starts up runs strong for 5 mins shuts down restarts runs for now only seconds and shuts off
sounds like the hi limit switch is shutting it down,because it is not getting enough water,cloged filter, valve to heater notopen,bypass valve not closed,open up the water releif valve with the pump running should be alot of water running coming out of it.
Jun 13, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Master heater only runs for 5mins
Check the photo eye to make sure it is clean,clean it with soap,and water,and add a additive to the fuel for gelling.
Jan 14, 2010 | Master Heaters B155DST
Dometic refrig runs on AC fine, runs on gas for 8 min. then off.
freon line may be plugged...try flipping it up side down for 24 hrs.. hope it helps
Sep 19, 2009 | Refrigerators
Vent free wall heater starves for gas
The 3/4 pipe will provide enough gas provided that it does not have a lot of elbows in the run. The more elbows you have, the less gas you have at the end of the run.
I recommend that you call the company which provides you with the gas and have them come out and look at your problem. They will be able to analyze your situatioin and make a recommendation to you. This is a free service. Good luck with it.
Jan 22, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
514 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
