Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Keeps freezing and gets hot
Will work for a while, then it freezes and then it starts again but freezes a few minutes later, i thought it mightbe the battery, but the zune gets very hot... any idea what it could be? or suggestions? 30g zune
  • 20 Answers
The freezing itself is most likely due to friction and heat created in the hard drive inside the Zune. The excessive heat you feel is probably due to the same problem.
I would suggest (if you are tech savy) opening the Zune (you can look up instructions easily) and cleaning out any dust you see inside the case. There COULD be a battery issue, so making sure the insides are clean and dust free is the first step!
You can use a small can of compressed air (available at any best buy, office max, office depot, etc.) to gently clean out any particles or dust. Best of luck!
Posted on Jun 25, 2009
Hoover a class fridge freezer both not working
Feel the top of the compressor and tell me if it is too hot to keep your hand on top. Model number is?
Appliance 911 Sea Breeze
Oct 13, 2015 | Hoover Refrigerators
Tried almost everything, please help
It is because It is because fat partitions dont suupport manupulation of files bigger than 4 gb. Convert it to ntfs and it will work. And you might wonder that it worked for 15 min. ISo when you play a game lots of cache is generated and size of game is nearly doubled so this causes problem on a fat partition. And on
Jan 07, 2014 | Sony Playstation 3 (PS3) Console
Picture freeze,long tme to restart does it again
Unless you have good / fast access to the Internet (or wireless or 4G network), it may take a long time to download a movie to your device. If the speed of download is slower than the speed of the play, the picture freezes ... essentially, it is waiting for the completion of the download for the next few frames (of the movie). That is why the picture freeze .... and it will start again after sufficient data has been download to continue / start playing (the movie) again.
Apr 30, 2013 | Cricket Wireless Cricket Crosswave WiFi...
The android started freezing after we used the internet it freezes on one screen what can we do to fix it?
try holding the on button and keep hitting the volume up and down button then restiing it again i did this and it worked
Jan 26, 2013 | Computers & Internet
AC will blow cold air for a few minutes then start blowing hot air, cut the engine and start it again and blow cold air for a few minutes then start blowing hot air again. Just filled up the freon and the...
you have moisture in the system this causes your expancion valve to freeze up an stop working, thats why it works for sort time and when it de-freezes stars working again. you need to do a EVAC & RECHARGE with a good AC service equipment, specially attention to pull vacumm por at least 20minutes so you get all moisture out of the system.
Good luck
Jun 05, 2011 | 2002 Hyundai Santa Fe
My A/C blows out hot air every couple days
The only problem I could think of is that the air conditioning needs to be recharged as they call it because over time it will run out. You can usually go to a place like Firestone and they will do it (depending on how much you need) for around 100 or you can find a way to do it yourself you would buy either R134A or Freeze 12 that might be harder to get but cheaper
Aug 19, 2009 | Whirlwind FH-778 Air Conditioner
Frozen screen
its probably just to hot thats why my friends play it upright helps cool it off but in your case i suggest buying a cooler for it.
Aug 16, 2009 | Microsoft Xbox 360 Console
Picture will freeze.
Either the disc is scrathed or you have to remove the cover and take a q-tip with rubbing alcohol and clean the lens.
Jan 22, 2009 | Cyberhome CH-DVD 300 DVD Player
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
129 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
