GE JVM1650 1000 Watts Microwave Oven
Fan comes on hwne open door
shared by 2 users
posted by Excarkun on Nov 04, 2007
fan or its actually running when you open door after its ran. Not all the time but most the time, just started doing it today..what to do?
Comment posted on Nov 05, 2007
Now its later in day it just doesn't run well or wont run at all. We had the magnetron replaced by GE earlier this summer.
Could it be the door?
A switch thats not working right when door opens or closes?
Never seen a microwave run while door open or its fan run.
Comment posted on Nov 06, 2007
well now the only time runs and not fan or heater at all come on when trying to run it...grrrrr
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on Jul 24, 2008
Fan runs when door is open
Best Solution
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 3407 votes
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Rating Locked! (?) Excarkun has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Fan comes on hwne open door:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
does not heat. everything else works - light switches etc....
These two lights have quit working. I pushed the light...
hellow i have a microwave but there is no problem with my...
i don't understand how to remove the old frame
Hi , Everything else about the unit works perfectly and it...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Microwave Oven Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
