Question about GE Dishwashers
Ge pot scrubber 650 model #gsd650x-73ba.
Dishwasher is humming when turned on and will fill but not wash and drain. checked pump screen and cleaned a little grime . Any suggestions
  • 9 Answers
SOURCE: Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Posted on Apr 20, 2008
  • 464 Answers
SOURCE: My GE pot scrubber won't fill with water, all kof
you are probably in need of a new water inlet valve part #WD15X10003, should be around $35.00. this valve opens up at the proper time on the timer to let the water into the machine. hope this helps.
Posted on Oct 15, 2009
  • 54 Answers
SOURCE: burning smell coming from dishwasher caustic to
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Posted on Apr 22, 2010
  • 523 Answers
SOURCE: The water didn't drain .
yes take a smaller hose and put through the drain hose then push drain/cancle
Posted on Jun 06, 2010
SOURCE: ge potscrubber 650 Dishwasher is humming
This happens when the DW goes unused for a while. The motor is stuck. Open up the lower panels and move the Motor Fan by hand until it moves freely. This worked for me until a seal broke.
Freeing the motor may break the seal between the motor and pump assembly. I'm in the process of replacing that now.
Check for leaks by running the DW before putting the lower panels back on.
Posted on Aug 17, 2010
I think the sump pump motor is broken. the water does not drain after a wash. approx 3" of water remains. Is this a sump pump issue and can it be repaired or should i buy a new dishwasher?
I have had the same problem with a brand new one,I called the engineer on this one as I could not do it on my own due to a stroke,he found a small piece of glass inside the pump not allowing it to run freely, I would check the pump if it is rotating first, you may have to take the pump apart to see if there are any bits in there, don't forget there will be water left in the hose, lay the hose out to remove the water and don't forget to unplug the machine first and turn off the water supply to it. I hope that saves a new washer cheers eric
Nov 12, 2017 | GE Coffee Makers & Espresso Machines
Whirlpool dishwasher, quiet partner 1. Does not drain, does not finish wash cycle.
ensure your dishwasher pump and drain hose are unobstructed. If your machine does not drain it will not refill with fresh rinse water and since it can't do that the cycle will never finish.
Many people don't completely rinse off food stuffs from their dishware, expecting the dishwasher to take care of it. To be honest, a dishwasher is more of a fine cleaning and disinfecting device than a pot scrubber. Because of this, grease, food debris, etc can clog the pump or drain line over time. be sure to use a good de-greasing agent regularly once the flow of water has been cleared (don't wash your dishes with it however)
Mar 20, 2015 | Whirlpool Dishwashers
Ge potscrubber 650 Dishwasher is humming when turned on and will fill but not wash and drain
Aug 14, 2010 | Dishwashers
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
Oct 15, 2009 | GE 24 in. GSD2600GBB Built-in Dishwasher
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
General Electric Pot scrubber Dishwasher
From what you are describing, the fill valve may have failed or become clogged. Start the dishwasher, when the water stops filling, open the door and check the water level. There should be at least an inch to an inch of water in the center of the tub. If not, replace the water inlet valve.
If you need further assistance, let me know with a model number
Regards,
reg501
Jul 21, 2008 | Dishwashers
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwasher dosen't drain completely
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Dec 08, 2006 | GE 24 in. GSD2600GBB Built-in Dishwasher
Dishwashers Logo
593 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
