Philips 60P8342 60" Rear Projection Television Logo
Posted on Jun 24, 2009
It does not power on even at tv - Philips 60P8342 60" Rear Projection Television
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jun 24, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
2173
Points
23
You will have to go into the service manual and check the start up voltages as they enter the set. The manual will show you which components to check for standby power and start up voltages.
2helpful
BPL TV NOT STARTING
if no any power indicator that light or even blinking, the first place to be check will be the power supply section you must check weather the fuse is blown.if the fuse is blown before you replaced with new one you need to check other component in the power supply section like transistor and diode. so this case need proper trouble shooting, if you think you don't have enough idea in any electronic repair just leave it to the trained tv technician.
1helpful
Tv won't turn on power indicator light not lit
As you mentioned the tv have problem with the power supply stage. Before suspecting for any intenal fault Chcek the following first. Remove the AC plug of the tv and connect the same in any other wall outlet. If then also it shows the same problem then its the powersupply board of your tv.
working on power supply board should be done by a skilled worker. Because there is risk of electric shock even if the power is disconnected. some of the capacitors will hold charge even if the power is not connected.
Here i have adde the link which will lead you the powesupply board.
Power supply board
Ajin
I have a Samsung 3D TV (46C7000).I have developed an intermittent sound fault. When the TV is switched on I get a high pitched Tone emitting from the TV over the sound of the broadcat program. Sound is...
The tv have a problems in it power supply board,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.Power supply board have some bad high voltages transformers.That why ur tv even getting a high pitched sound even the tv it is off and tv it is not even on,and tv it is on standby mode only.
2helpful
My proscan 42" LCD tv
hi; do check the AC cord if still good.
if your LCD TV wont start , even if you press the power button , it has a power supply failure, maybe some capacitor has bloated or changed value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician.
thanks ,, hope this helps........
I got samsung tv ln32a330j1d it won"t turn on even
You have a bad power supply.
You can get get parts for this tv at www.interliquidparts.com
Tv turns on and off itself , now wouldn't even come on. removed from wall socket and re-attached. attempting the sleeper timer, but tv won't even come on with further attempts. what to do?
Power supply problem. Look for bad capacitors on the power board circuit.
This information is for someone that knows electronic.
1000s of volts inside the TV that can kill. Even if you unplug the TV the high voltage can be stored inside the TV for days.
Best of luck.
www.aaatvservice.com
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
1helpful
ILO 2706 TV WONT TURN ON
This TV might have been affected by the power outage even if it was not ON at that moment. There is a standby voltage still present even when OFF and connected to the AC line.
There might be different failures on this TV:
1. The power supply might be defective after the power outage.
2. The main board could also be defective since the power supplies for today's TVs are not well regulated and once the voltage getting to the power supply increases, the standby voltage voltage will also increase damaging voltage sensitive components like the microprocessor or memory circuitry.
Let me know if you require further assistance.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
