Question about Maytag Atlantis MAV7000
MAV6200AWW; fill correctly then nothing, does not cycle at all
Well basically the washer will fill up and then not cycle any longer. we have changed the timer, checked the lid switch for functionality, it's okay, now my husband is checking the motor to see if it is getting power and for some reason it is not, help!
  • danalaurabar Jun 24, 2009
    Well, my husband retested the lid ( after he put new batteries in his meter, lol!) switch and found that the circuit is not closed when the lid is, therefore, no power is getting to the motor. I just ordered a new lid switch. Yeah, he believes that the switch is malfunctioning. Hopefully that is the problem, I love this washer!
    thanks so much, I'll let you know if this works
  • danalaurabar Jun 26, 2009
    Well, we replaced the lid switch and whaaa la! we are now up and running! Thanks for responding.
  • 530 Answers
If the motor is not getting power are you sure you properly checked your lid switch? when you close the lid slowly do you hear a click sound?
Posted on Jun 24, 2009
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
Jan 14, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
Maytag mav6200aww washing machine doesn't rinse clothes
If you say this only happens on the Colors and Whites cycle i dont see what the lid switch or balance sensor (if your washer has one) would have to do with it. It does seem like it has something to do with the timer,,, it really sounds like maybe the (Colors & Whites) section of the timer is malfunctioning. Inside the timer, there are a series of gears and switches, and by slamming the lid, or tapping on the timer control knob,,, it could maybe help the damaged part of the gear move, temporarily "fixing" the problem
Mar 13, 2009 | Maytag MAV6200 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Aug 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
163 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
