Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Whirlpool Stove Self Cleaning Oven mechanism won't shut off
Noticed the cleaning light and sound went off this morning. Oven door locks and has been in cleaning mode since this morning non-stop. There is no heat. What do I do?
    Sergeant:
  • 199 Answers
Pull the power cord it should hopefully un lock the magnetic lock
Posted on Jun 24, 2009
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    Door will not unlock after cleaning
    It usually takes at least an hour or more for the oven to cool down to a "safe" temperature and then it should unlock for you. If by morning it still is not unlocked, cutting the power (circuit breaker may be easiest) for 3 minutes should reset the electronics.
    Mar 26, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
    I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
    Seems OK now.
    Oct 15, 2009 | Ovens
    I did a self-clean session and the oven remained locked way after it completed the cleaning. The error message on the backsplash reads E1- F5-. I am not able to open the oven. What's wrong?
    I hit the cleaning button instead of the broiler and the oven lock went in mode so now it thinks it is cleaning but I can't close it and it won't shut off the cleaning mode. What can I do?
    Sep 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
    This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
    Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
    Jun 03, 2009 | Ovens
    Self cleaning oven won't start self clean mode
    NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
    Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
    Oven Lock stuck open before start of self-cleaning cycle
    Sounds like you bent the door where the lock is. You might have to replace the door.
    Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
    Self cleaning oven directions
    MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
    Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
    Self cleaning won't shut off
    that is because it needs to cool down before the oven will unlock.There should be a timer running and when it gets to "zero" it should unlock.
    Jul 08, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    276 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
