Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Makes squealing noice when turned on
My monitor is making a weird noise when I turn it on. I is kind of a squealing noise. It does it for about 4-5 minutes and then it stops and is fine until I turn it off and turn it back on again later. Other than that it seems to be working fine. Any ideas??
  • Anonymous Nov 07, 2007
    I need a new DC power adapter for my VA 720 monitor. Viewsonic Part # A-AD-0114-0146 or (HJC 4A)
    Problem Solver:
  • 22 Answers
Make sure that the audio wire connected to the your monitor is fine or try 2 replace it and also makesure that the wire ome the main power which is connected 2 the switch or pc is fine and if necessary replace it i hope it works
Posted on Nov 05, 2007
When I turn heater on it makes loud noise & wont heat up
Paula, it sounds like your heater fan motor has died and gone to heaven. You did not describe the noise but if it's kind of a squealing noise you need a new motor installed. Should be under $300.
Oct 25, 2013 | Cars & Trucks
When i turn the key to start it up, it makes a loud squeal like sound, what is that?
starter may be going bad sounds kinda like a loud metal on metal grinding noise.
Apr 01, 2013 | 1990 Mercury Grand Marquis
DW makes a lot of noice when it's washing....squealy, whiney noice...very loud.
Hello Summer Summer - Often if the dishwasher is making a loud, squealing noise then it is recommended for the wash motor to be replaced. If this problem persists, you can locate a certified technician directly through the manufacturer website or in your local directly to determine what may be causing the issue at hand.
Mar 12, 2013 | Frigidaire FDB1100RHM Builtin Dishwasher
My 2004 t&c 3.8 is making a weird sound like a
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Exhaust Fan makes noise
Check to make sure that nothing is obstructing the fan blade causing the noise, if not then the bearings in the fan motor are more than likely going out causing the metal on metal noise.
Apr 24, 2012 | GE Microwave Ovens
My 92 4 runner makes a squealing noise when I turn. It only makes the noise when I start to accelerate in the beginning of turning. If I slow down on the gas the noise stops alot quicker, then if I keep on...
Most likely need to replace you accessory drive belt. However, before you do that make sure the tensioner is bringing adequate pressure to bear on the belt. The squealing is probably the side of the belt slipping in the metal drive pulleys.
Jan 30, 2011 | 1992 Toyota 4Runner
How do i turn off the high pitched frequency noise
If what we are talking about here an old model of monitor that has a bulky back, the high pitched frequency is caused by other electronic devices such as your speakers.
- Relocate your speakers away from the monitor
- do a factory reset on all settings on the monitor or if possible, do a degauss.
Dec 16, 2009 | Computers & Internet
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
'96 Toyota 4-Runner makes a loud squealing noise and brake light
Sounds like one of the auxillary belts slipping it may just need tightening up. I think the 4-Runner has two belts one large and one for the steering pump
May 13, 2009 | 1996 Toyota 4Runner
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
414 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
