I do not have remote 2 year old threw it down heating vent. I have universal remote but really does nothing. TV is set to aucun signal YPbPr1. When I push imput I see the choices and have tried each one I just want it to go back to receiving the cable box so I need tv set to channel 3. How can I do it manually?
  • 767 Answers
Press input repatley until you get to (ant 1)
or (ant 2) then press the chanel up/down to
get to ch 3 make sure the converter box is
conected to ant input.
Posted on Jun 30, 2009
I have a magnovox TB110mw9 reciever that the audio button on remote does not work. it is hooked to a magnovox 20mt1331/17 tv. we have a RCA universal 4 device remote programmed to both. my 2 year old...
Universals do not do specific buttons like the AUDIO button on your Magnavox. Instead of wasting up to $20 on a universal that probably will not work, you should by the original remote for whatever it costs, because you know it will do all the features for your Magnavox unit that it has to offer. Many times ReplacementRemotes.com will get Refurbished remote available for really cheap. LIke $10 - $15. You can subscribe to the product so next time they get one in, the site will notify you immediately that they are in-stock.
Oct 18, 2013 | Televison & Video
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
The TV can't be operated by the remote anymore. I changed the batteries with new ones, unplugged the tv for a night and did a factory reset but nothing helped. It's not the remote because my universal...
The remote IR receiver may have gone out, or the logic board is not processing the IR signal from the IR receiver board. You can check and see if the IR receiver board is getting 5vdc feeding it.
See the parts for your TV here: www.shopjimmy.com
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 25, 2010 | Vizio L32 32 in. LCD HDTV
Tv wont go to hdmi1 and is stuck on dvd.
I think what is happening with your tv is it does not see the signal. If there is no signal going to the tv it will not let you select the source you like, in this instant HDMI 1. What you probably need to go do is look at you dishtv set top box and go to that box's menu and enable hdmi output. Hope this helps.
Mar 08, 2010 | Logitech Harmony One Advanced Universal...
Installed a Wii to YPbPr1 port. display is B&W, no color. How do I get the display in color?
Unless the Wii is sending the video signal in component form, you have a case where the signals are not compatible. The Wii is sending "composite" and the TV is expecting component. With the composite signal the Y input, the result will be a B&W picture. Either set the Wii to send component or connect it to the composite input on the TV.
Dan
May 12, 2009 | Televison & Video
My remote control stopped working....
If the light on the tv does not flash when you press and hold a button it is not getting a signal from the remote. Your remote is bad. Do you have a cable or satelite remote you can program to work your tv? If not I think you need to go buy a universal remote and set it up for your tv.
Apr 05, 2009 | Sansui HDLCD-2600 26 in. LCD Television
Help pleaz
1- make sure that the batteries are new and installed the right way (follow the diagram under the batteries).
2- if you threw out your manual download a copy at www.retrieve.com
Mar 15, 2008 | Philips Magnavox 20MC4304 20 in....
Can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Dec 15, 2007 | Toshiba 27D46 27" TV
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
