Question about Lenovo 3000 N100 Notebook
My Lenovo N00, 3000 notebook came with a 10.8
My Lenovo N100, 3000 notebook came with a 10.8 volt, 4.4 AH battery. To replace it, I ordered a 11.1, 7200 mAh battery. When I replaced the battery, it fit perfectly but when I booted up my computer it said, "Windows did not start properly. You may have, either, new hardware or software". I couldn't get it to boot up in regular or safe mode. Does this mean I have the wrong battery? The place where I bought it assured me it was compatible with my model laptop.
elsand711
  • elsand711 Jun 25, 2009
    I couldn't get that to work, either. I've given up and am sending back the battery. I thank you for your time.
    Sergeant:
  • 199 Answers
Boot up holding f8 key load last known good configuration. your computer should not know jack about the battery. but with computers you can never tell they are finikey
Posted on Jun 24, 2009
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
Tip
Levono 3000 n100 Notebook shuts down all the time
1. Pull out the battery.
2. Open the panel on the bottom that has the fan and remove the fan and heat sink. 3. Clean the top of cpu, 4. Put some thermal paste on the cpu
5. Put it all back together. 6. Safely dispose of the battery, If you plug the battery back in you will have to go through the whole process again 7. Run off ac adapter.
8. Buy a new battery.
on Jun 10, 2010 | Lenovo 3000 N100 Notebook
How can i replace the cmos battery for lenovo 3000 n100
it is tricky and i highly recommend that you give it to an IT expert to change the CMOS battery.
Oct 06, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Lenovo n100 is 10 minut after power off.
If you are running on battery power and it powers off, then the battery is not fully charged or the battery is worn out or faulty.
Rechargeable batteries have a finite number of charge and discharge cycles and after 2 or more years they will lose its charge capacity until it will not charge at all.
A new battery will solve your problem provided the charging circuit in the laptop is OK.
Sep 26, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 Notebooks : N100 Power Failure!
Hi.. I have a temporary solution to your problem. I had the same problem. Remove the battery and the ac adapter from the laptop. Just reconnect the ac adapter without the battery and switch on the lap. Presto.. Problem solved.. It doesnt power off anymore unless u remove the ac adaptor. Usefull if u hav needed files n want 2 create a backup. Still i havent found out a permanent solution to this problem. I suspect its a motherboard fault
Jan 22, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Wi-fi connection
Looked at the specs on your laptop and you have the wireless card included. I assume you have a router set up already or you have access to another wireless network. Follow these steps to access it from your laptop:
1. Go to START
2. select MY COMPUTER
3. Once in the new window, click MY NETWORK PLACES under the "OTHER PLACES" section
4. select the VIEW NETWORK CONNECTIONS link under the NETWORK TASKS section
5. RIGHT CLICK on your wireless network connection and choose PROPERTIES
6. click the WIRELESS NETWORKS tab.
7. make sure the "USER WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS" box is checked
8. Click OK and close the window
9. RIGHT CLICK on your wireless network connection (the name of it) and choose REPAIR
10. if windows detects the wireless connection, you should see a bubble near the task bar
11. in order to begin using the wireless connection, open your web browser then enter your username and password (if required)
Dec 01, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Lenove 3000 n100 batteries
the battery casing itself is heat sealed....
You Need to Pry it open..
No Really easy way to do it and you must take your time and do it slowly, start at a corner edge using a guitar pick or similar... then work your way around and around till you can pry it open..
Not an easy task.. But Do-able..
Nov 17, 2008 | Lenovo 3000 N100 T2350 1.83G 1GB (0768EFU)...
No battery charging
you need to replace the battery.
Nov 12, 2008 | Lenovo 3000 N100 0689 Notebook
Lenovo N100 dual centrino
visit lenovo.com u can get certain things to make your laptop faster.......
Aug 18, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Lenovo 3000 N100 Notebook Logo
122 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
