Question about GE GSS25LGM Side by Side Refrigerator
My compressor it not comming on On the circuit board I Jump line to comp but still nothing could the compressor be bad
    President:
  • 744 Answers
If compressor is clicking it will be the relay, If the compressor is cold not making any noise it sounds like the defrost timer stuck in defrost cycle..if it is a mecanical time advance it ..if compressor starts replace timer...some refridge defrost timers are built into control board so anly way to find out is replace board. Hope this helps...feel free to comment again if i can assist you further.
Posted on Jun 24, 2009
  • 351 Answers
Either its not getting its juice or the relay is bad doubt it could be the compressor but it does happen
A/c comp.won't kick on tryed to jump pressure switch still nothing fuse is good 1989 Chevy 5.7 comp.is new
There is also a relay to check. If relay is ok, the compressor clutch or wiring to it may be faulty
Jun 07, 2015 | Chevrolet Cars & Trucks
My goodman dsz160361ae outdoor unit will not start. it tries for 4 seconds then shuts off. I changed the comp. and the circuit board and the start and run caps. could I have the wrong circuit board? I
Most generally the original circuit board has a model number on it that should be the same as a replacement board. If it does not match, then you may have the wrong replacement. Why did the board burn up? It may have caused a short that you have not diagnosed, thus possibly shorting out the new board. The fan stays running because the call for cooling is not satisfied.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Apr 02, 2017 | Heating & Cooling
1998 ferd e150 how to jump a/c to charge comp comp not running williams 1042 @roadrunner.com
no way to charge AC with out proper gauges ,once gauges are on it will tell if there is freon in the lines or not ,most likely there is a leak somewhere,if there is enough freon inthe lines and the comp still won't engauge it looks like a new compressor
Apr 15, 2010 | 2001 Jaguar S-Type
Does not make cold, main compartment or freezer, replaced "relay/overload" capacitor (?) but still cycles/clicks off and on - lights on and motors run but no cold.
if clicking off and on I would say . the relay is working but the compressor is not starting . if comp will not start ( no cold ) the fan by the comp runs when the comp runs / but if comp does not start the fan does not know .. if comp runs the lines one is small and other is larger . the small one gets hot enough not to touch.it . not hot no cool . I think you have a compressor problem .. **** hope this helps . get back with me .. //mm
Jan 06, 2010 | Amana ABB1921DE Bottom Freezer...
Mr. Heater Natural Gas Garage Heater - 45,000 BTU. Power 120 volt and 24 volt good. Thermostat calling for heat, but nothing happening??
Check for a fuse either in-line or on the circuit board. There should be 24 volts going to the thermostat. If not, you have either a bad transformer or a bad thermostat wire. Jump out the terminals that the thermostat wires are connected to. This should force the unit to fire. If not, bad circuit board.
Dec 23, 2009 | Mr. Heater Natural Gas Garage Heater -...
GE PSS25MGMCAA refrigerator - Bad circuit board??
You need to change the board . Part number WR55X10656 . The board relay , cannot be changed . Power surges , dirty condensor coils , and usage , are the most common causes , for board failure .
Sep 23, 2009 | GE Refrigerators
I have a GE profile refreigerator model PTS25LBMARWW. It started to defrost in the freezer. I have working knowledge of refrigerators as I completed A/C and refrig. trade school 20 years ago. here is the...
Make a insulated jumper wire.
Remove the circuit board panel.
Jump the line in side with the compressor terminal.
On the bottom of the control board you will see a molex connector with 3 wires. That is where you will see the 3 terminals.
If the compressor and fan motor come on after the jump.
Replace the control board.
Mar 10, 2009 | GE Refrigerators
No cooling on eather side
No, white to com, black to the run terminal, and to the start through the capacitor. I suggest you also have a 15-amp fuse or breaker in the line for protection. Given that you say the relay, cutout, and cap check out, and you say there is continuity through the compressor, I have to think that there is a high-resistance connection in the circuit that feeds the compressor. Suspect bad connection at the thermostat or the defrost timer. Be careful, and work with one hand behind you back so you do not receive a dangerous shock.
Dec 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Compressor not kicking on
i can help there should be a blue connector on the bottom of the board that has 3 wires. They are labeled on the board as line, def, comp. Jump line to comp. Comp should come on. Let me know what happens
Nov 28, 2007 | GE GSS25LGM Side by Side Refrigerator
Side by side stopped working but clicling noises every second two.
Read, this model posted has a main board in back that controls the refer. Your problem sounds like the overload and relay on the compressor but you need to do a test to verify. On the main board in back there is a blue harness, 3 pronged, that is marked line, defr and comp. Lower left hand corner. You need to get a jumper wire with alligator clips and with the plug out, jump line to comp. Now plug it back in, this will send 120V directly to the compressor. See if it starts. If not and it does it clicking thing, chances are it's the overload and relay, or the compressor itself. You have five years warranty on the compresser. If it starts, it's the board it's the board giving you the problem. This of course is for the GSH model posted...Catriver..post back.
Feb 11, 2007 | GE GSH25KGRWW Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
208 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
