Question about Hitachi 42HDM12 42 in. Plasma Television
When connecting dvd to hitachi 42hdm12a, screen said something was corrupted. Now, can't get picture. HDMI searching but won't get picture. help
  • chickapee Jun 27, 2009
    Thanks OTBobby. Problem solved. Guess what? When I checked
    the HDMI cable, it was bad. Tried a new one and got my picture!!!!!
    Big hug for you!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
1.Press [stop]button on DVD player to Stop DVD Playback
2.Press the [resolution] button on the DVD player.
3.change resolution to 480p
if you get a picture in 480P, continue your setup of the DVD player
If you still have no picture perform the next steps (stop at the step if you recieve a picture):
4. verify the video input of the DVD player to the TV and reselct it on the TV
5. use Video cable to verify the DVD player is still working
6 disconnect/reconnect HDMI cable to TV
7. power off/on the TV
8. power off/on the DVD player
7.
5. turn off TV then Tunr
Posted on Jun 24, 2009
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How do i get the hdmi working
HDMI start by putting one end of the HDMI cable in the HDMI socket on the tv, then the other end in the HDMI socket on the device your are going to use. It can be a decoder, an apple tv or something else that needs an HDMI connection to the tv to work.
Secondly find the remote control and push the input button then there should be a picture on the screen with different possibilities for input. Click where it says HDMI.
You should be connected now,
kolbrub
May 25, 2014 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
Cannot change the picture back to full screen. remote control want return the picture to full screen with the
Hi, Turn your TV on, select the menu and see if there is something in picture settings (wide screen or full screen) Try to connect a DVD player using HDMI cable. See if there is any difference.
Some DVD players will also have screen sizing. If nothing helps contact TV repair. Good luck
Jul 24, 2011 | Hitachi CLU-5713TSI Remote Control
Hitachi 55HDS 55 Inch Plasma Picture Problem
Hi Mhansen884,
This type of failure is due to a defective upper and lower scan boards.
Check the link provided to see what the parts look like and or to find the part numbers if you would be DYI,
Mar 03, 2017 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi l42vpo1u no sound through hdmi
HDMI port damaged, mainboard need to be replaced.
But be absolute sure your HDMI port is not working properly, I recommed you try it again with another HDMI cable, you can also try same cable in another TV.
Bye
May 18, 2009 | Televison & Video
Floating Horizontal Line
Sounds like a bad component on the video board. These days, TV techs just swap out boards for whole new ones.
Nov 17, 2008 | Hitachi 42HDX62 42 in. HDTV Plasma...
Connecting DVD VR357
direct to tv always best picture ok hdmi then sound from tvs digital outputs to input on your digital reciver ok
Jan 18, 2008 | Samsung DVD-VR357
No picture on my hitachi 57f500 when i connect hdmi to dvi from new dvd Player
If you have a 2006 or later model, you must set up Blue Ray DVD to Auto Mode on their output setting.
Dec 07, 2007 | Hitachi 57F500 57" Rear Projection...
Open Questions:
Hitachi 42HDM12 42 in. Plasma Television Logo
309 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
