Question about Motorola Mobility SLVR L7 Cellular Phone
Removable storage when I try to set the camara for removable storage it says my card is not formatted. It gives the option to format the memory card but fails.
  • Anonymous Nov 08, 2007
    when I try to use my camera for removable storage it says my card is not formatted. It gives the option to format the memory card but fails.
    Brigadier General:
  • 7,752 Answers
Place the card into a card-reader and connect it to a pc and reformat the card this should fix it or try master resetting and clearing the phone to see if that also helps.
Posted on Feb 16, 2008
STORAGE CARD NOT WORKING - Your memory card has changed is damaged or is non-compatible. To fix this, turn your phone off and either remove the memory card or replace it with a new compatible card. Then...
To check your memory card ,you need a memory card reader.
insert your memory card into the reader and connect the reader to the USB of your PC. save your data if needed.
if its reading try to format it in your Pc by right clicking the mouse.
format option. then insert the MMC back to the phone and format it in the settings menu/storage.
your memory card will work fine.
if you cannot format using your PC replace the memory card.
Dec 09, 2017 | HTC HD7 Cell Phone
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How to format my memory card using pc?when i press the data storage mode,it starts formatting the memory card in mobile & the mobile as usb doesn't show up in how can i format it in pc?
You just need to remove you are memory card from you are mobile and place you are memory card in card reader slot.After that connect that data card to you are pc.Then open my computer there you will find as removable disk right click on it.Then there will be number of option in that select formatting after that select quick formatting then a new window will open telling that all information will be erased.Then give ok then it will format.Thanks for your question.
Jun 20, 2011 | Nokia Cell Phones
I cant reformat my phone memory in my motorola w388, i try to follow the steps to master clear but it still unable to work. is there something i can use to reformat my phone memory??its getting worst
All you have to do to reformat the memory card is that you have to
insert the memory card, press the Center Select Key,scroll to and select Phone Status, scroll to and select Device Info, scroll to and select Storage Devices,select Memory Card and press Options, and then select Format.When prompted, press Yes to continue or No to cancel formatting.
Another step for you to be able to reformat your memory card is you just have to
press Main Menu,scroll to and Select Settings,scroll to and Select Storage Device,scroll to and Select Memory Card,scroll to and Select Format Memory Card, and then
highlight Yes and press the Center Select Key.
And this will also be an option for you to format your memory card.Here are the steps:
Insert the microSD card.
Press Menu > Settings > Security.
Enter your lock code.
Select Format External Memory. (A warning will be displayed.).
If you are sure you wish to remove all the files from your microSD card, select Yes (left softkey).
Apr 17, 2011 | Motorola Mobility W388 Cell Phone
I have just recieved my camara today. when i turn the camara on it says ''storage error'' and when i try to take a picture it says '' card fuul'' ???? i have re formated the memory card, changed the...
Change the primary storage to save the pictures to memory card and not the camera's internal memory. If you can't find the place to change the settings, let me know the brand and model of your camera and I will see if I can give you detailed instruction how to change storage location. You can also refer to the user manual. Good luck.
Sep 23, 2010 | Cameras
How to format my motorola l7 using its own keypad?
Memory card Format:
"setting"--"phone status"--"storage device"--"memory card"--option & "format"
Phone format:
"setting"--"initial setup"--"master clear"
please note
Master clear will remove all "contacts & messages".so take back up first.
vote for me..
Aug 01, 2009 | Motorola Mobility SLVR L7 Cellular Phone
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
Mar 19, 2009 | HTC S710 Smartphone
No format memory card
Make sure the lock switch is set to off on the cards you are using. That would prevent you from using them.
Feb 04, 2009 | Kodak EasyShare C613 Digital Camera
Digital camara and memory card
Basically picture files in memory card have corrupt data that's why computer doesn't recognize it.
HP recommends following action...
Close the HP Image Zone or HP Photosmart Software, disconnect the camera from the computer, and reset the camera. (can see this at HP Support)
2nd option is to find some memory card data recovery software on internet and use it to correct data files in memory card.
Thank you.
Oct 03, 2008 | HP Cameras
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
