Question about Panasonic NN-P794SF Microwave Oven
How do I disassemble my microwave oven door?
I have a Panasonic NN-P794SF microwave oven. The door will not latch closed.
The door latching mechanism consists of two hooks on the door end which mate with receivers on the microwave. I believe a spring has come loose, which would normally push the hooks down to latch the door when proper engaged.
I can hear the (presumably) spring rattling around when I swing the door.
Should be an easy fix, if I can disassemble the door without damaging it.
Thanks in advance!
MicrowaveSvc
  • 9098 Answers
SOURCE: the door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Posted on Sep 23, 2007
SOURCE: Door Disassembly
Drilling a little hole from the inside-out and putting a little screw did the job in 10 minutes. Awesome recommendation. Thanks.
Posted on Jan 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Need door assembly diagram to
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: door does not latch close
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Sep 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
Door will not open. Nothing broken in the mechanism
Hi Glen,
Have you taken the wrapper off of the unit to open the door? You usually have to use a pencil or small screwdriver to lift up on the bottom latch head (doorkey as Panasonic calls it). These counter top models typically use a three step method to open the door. The push to open button pushes on a lever that then lifts up on the bottom doorkey. The lifting lever cracks and won't support fully the weight of the doorkey. The crack can be small enough to not really be noticeable if you are not very familiar with this problem. I'm pretty sure that this is what you will find. Let me know..
Oct 21, 2013 | Panasonic NN-P794SF Microwave Oven
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
The top door latch on panasonic microwave NN- T945SFX broke
it's a replaceable part. the upper and lower hooks are actually 1 part. door will need to be partially disassembled
Aug 03, 2011 | Panasonic Microwave Ovens
Door closes but will not turn on . Have to slam it Model # NN-SD698S Inverter S/N 6810190386
There are micro-switches in the control panel that are out of adjustment or sticking.
The switches have to make contact with the door latches when the door closes.
Adjust the position of your switches.
Jun 11, 2011 | Panasonic Microwave Ovens
Door does not secure when closed
Hi , Either you have a faulty door interlock switch(es), or the door latches (on the door) have been damaged and will not activate the interlocks. either way, you have to be conversant with adjusting microwave latch assemblies once the repair has been effected AND THE USE OF AN OVEN LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be subjected to harmful levels of microwave radiation.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Panasonic NN-ST666W Microwave oven
What usually breaks is the door open lever, but it may be that the rear of the door open button and the face of the door open lever are worn to the point where they will not actuate.
On a counter top model, the outer cover will need to be removed to diagnose and repair this.
On an over-the-range model, only the control panel needs to be
removed in most cases.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Panasonic parts in Australia here.
Dec 07, 2008 | Panasonic NN-P794SF Microwave Oven
Door does not latch close on the Panasonic Microwave Oven Model No. NN T444SF
Aug 26, 2008 | Panasonic Microwave Ovens
Door will not latch
The door switch mechanism is broken. Microwave doors have a special arraingement of double switches to ensure it is not open during cooking. Because everything is made from plastic nowadays, stuff like this breaks easily. The switches are commona nd cheap but the mounting parts may not be.
Dec 28, 2007 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-P794SF Microwave Oven Logo
168 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
