Question about Sony KP-53HS10 TV
Pip I cannot remove the pip window from the main screen. It will move around and change size, but will not go away.
  • chuckboone Apr 04, 2009
    I had the same problem. Found this forum. Used the solution and it worked! I have buddies coming over tonight to watch the Final 4. Whew. Thanks!
Push the flash focus button one center control panel (on the front of the set0
Posted on Nov 07, 2007
No picture on main screen
Sets with PIP use two tuners--one for main and one for PIP---likely the main got hit with the static discharge during the storm----Here we always disconnect both power and cable when a storm.
There is a way around this (will lose PIP) with a cable box connected to the audio and video inputs on rear of set---bypass the tuners and use the box to change channels and provide signal.
let me know if questions.
Nov 07, 2012 | Televison & Video
I cannot get the picture-in-picture off the screen
You must press function before you can control PIP with the yellow labelled buttons.
Press to change the TV channel in the window picture.
Press to move the location of the window picture [counterclokwise] around the main picture.
Press to freeze the window picture with Freeze button.
Press freeze button on the remote handset again to restore the previous screen.
Oct 26, 2010 | Sony KV-27V65 27" TV
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hitachi TV: 35TX30B Window in upper left view that won't go away
you using a digital desk top box with it ?
an old school tv
solid state old analog
what you are seeing is called picture in picture
one of those split screen functions of years past
remote may have a function button on /off for that
user manual for one
Hitachi 35TX59K 35TX50B 35TX30B Manuals
Apr 06, 2017 | Hitachi Televison & Video
No picture in picture regardless of any way I wire the tv HELP
Thank you for providing the exact brand and model number of your product.
What it is: PIP lets you watch a second program in a little window. More-elaborate versions can resize the window, move it around the screen, create still or multiple still images, or simply divide the screen into two same-size pictures, often called "picture-outside-picture" (POP).
What it isn't: PIP has a dirty little secret, though: If you use an external tuner such as a cable box or a satellite receiver, you can watch only one program at once. If some of your channels are unscrambled, you can watch those on the second window, and you can usually watch other sources such as VHS or DVD on it, as well. But even with two-tuner PIP, a single cable/satellite box will prevent you from watching two live scrambled channels simultaneously unless the box itself has two-tuner PIP.
Thank you for choosing FixYa!
Sep 20, 2008 | Samsung LNT3242H Television
Picture in Picture
I have the same TV. My remote control has a PIP OFF. If you don't then you have the wrong remote control.
Aug 06, 2008 | Sony KP-53V45 53" Rear Projection...
Mitsubishi 60603
try switching your pip to the main screen and see if the pip shows blue while the main screen works.
May 29, 2008 | Mitsubishi VS-60603 60" Rear Projection...
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
Main screen color seems overmodulating. PIP subfeed color fine. White like under black light.
rule number one about all vs chassis with vertical can pip boards take them out and throw them away i could fix one but you couldnt beleive me and it wouldnt be worth your while do a search on your modle number until you come up with instructions on how to add two caps to the pip board connector to bypass it until you do this you are wasting your time Mitsubishi ... we're still building Zeros
Dec 08, 2006 | Mitsubishi VS-50705 50" Rear Projection...
Sony KP-53HS10 TV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
