Question about Sony PSP (Piano Black)
Battery or charger?
How do I know if it's my charger or battery thats not working?
  • 10,515 Answers
Swap the charger. Use some other charger. If found it's working, then it's already decided who is at fault.
If you cannot borrow it, you need to have a tech's hand to use instruments to check that.
Thanks for using "Fixya".
Posted on Jun 24, 2009
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Feb 27, 2016 | Cub Cadet Garden
Why is it not charging?
1 Battery no longer holds a charge
2 Charger is faulty
33 Charger circuit does not function
This is assuming the mains socket works ok
Try a different charger, if that does not do the trick you know it is either batteries or charging circuit. Then change batteries, if that does not work you know it is a charging circuit fault
Jun 11, 2015 | Tablets & eReaders
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David
It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop.
Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
Feb 28, 2014 | Acer Aspire 7720 Notebook
I have a B&D 24 volt drill/ flashlight/ skill saw combo, reciently either the battery or the charger is bad, I put the battery in the charger an the light on the charger flashes (even when unplugged)...
If the charger is lighting up its probably the battery. Rechargable batteries have a lifespan governed by the number of charges.
The only sure way of knowing is to have another battery or charger that you know does work.
if it is the battery its normally cheaper to buy another complete drill.
Sep 13, 2011 | Black & Decker Black And Decker FS24C...
My mini phone will not charge or switch on
First, the battery is drained, therefore any effort to turn it on will turn out abortive. Connect the charger to the phone and leave it for about 30 minutes to see if it will charge. If it does not charge then it means there is a problem.
The problem is most likely from either the charger, the battery or the phone. You need to diagnose each of them to know where the problem is from. To diagnose them you need to test them on other devices in order to know where the problem is from. First test the charger on another phone to know if it works. Then insert the battery into another phone and try to charge, remember the battery is drained and need some minutes to boost before indicating a charge, then finally, try another battery and charger to know if it will work.
Which ever does not work of the charger and battery need to be replaced, but for the phone, it is the connection port that need to be fixed if it does not work.
Thank you for using fixya
Caseytech
Jul 01, 2011 | Cell Phones
Hi. i have a sony dsc w130 and it says use only with compactable battery only. i know why that, coz i charfhe it with a universal charger. i heve tried short circuit, and nothing happends. i bought a new...
It is important for you to know that the specified charger that it is supposed to work with has a special method of charging it as the battery is a very delicate one. That is why it is specified that you have to use a compatible charger.
When you use a universal charger, it does not charge the battery as the battery is supposed to be charged. This inflicts some minor damage on the battery and makes it impossible for the battery to work.
The compatible charger has a unique spontaneous way of emitting charges into the battery and the universal charger lacks this. So when the universal charger is used, it does not emit the right amount of charge into the battery.
The only way around this is if you can modify the charger or the battery in such a way that it might work. But then, you maybe damaging your camera. Instead, buy a specified charger.
Hope this was helpful? Please comment for more information and thank you for using fixya.
Jan 24, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Casio Exelim EX-Z77 battery will not charge, charger light flashes on and off.
Your battery maybe drained, you can try to leave it in charger for hours( it will take long for a drained batt to start charging) blinking led may indicate that charger is trying to supply current to batt, anyways I strongly suggest you to buy a new one
Apr 14, 2010 | Casio Exilim EX-Z77 Digital Camera
BATTERY DOES NOT CHARGE AND CHARGER DOESN'T LIGHT UP
If your charger is plugged into the outlet properly and you know it does work with other batteries, what you have is an internal open in your battery.
I have seen this happen, not sure what would cause it, but batteries can open up inside. Could be as simple as a cold solder joint inside where the batteries connect to the leads mounted on the case or worse. Either way, that is most likely your problem. Time to get a new battery if you know the charger is good. Other wise if the charger doesn't light up for any battery, then you have a defective charger
Sep 06, 2009 | Audiovox GMRS200W (14 Channels) 2-Way...
Sony PSP (Piano Black) Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
