Question about LaCie Ethernet Disk (300788) 1000 GB Network Hard Drive
Same problem here
My Ethernet Big Disk stopped responding when powered on. I get the blue light on the front, but I can't hear the drive spinning up, nor do I hear the fan spinning. I cannot even hold the front button to power off the device. It simply stays on all the time.
Is it possible to actually pull the drives out of one of these things and mount it directly to my system? I did this with a WD Mybook which had an SATA drive inside. The drive works great, just the enclosure had died. I am hoping I can do the same with this one, but I am not sure, since it has this funky interface where I have to create shares and users.
2 Suggested Answers
SOURCE: Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Posted on Oct 24, 2009
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
Hitachi touro not responding
Hi can you hear any spinning whirring noise?
This could be a cable fault or the drive itself could be faulty.
You can download Hiren Software on USB to test the drive with the software
Sep 25, 2016 | Hitachi Touro Mobile Pro 500 GB USB 30...
Sony ps3 with kes-410aca laser not spinning
seems like u have a bad ribbon cable.. that can cause the problem.. i had the same problem with many consoles,
before u buy a new ribbon cable, try to clean all ribbon's connectors with a connector cleaner spray.
Feb 14, 2013 | Sony Playstation 3 Blu Ray Laser Drive...
I formatted the hard drive connecting it directly to the computer (using Windows XP). Then when i reassemble the Ethernet Big Disk, it turned on but it doesn't do anything. My question is: Is the...
the OS of the Ethernet Big disk is on the hard drives, so you did erase them. This unit should only be formatted using the administration page drive format option.
LaCie usually does not give away the OS, so your option would be to close some other Ethernet Big Disk or Ethernet Disk Mini drives unto your now formatted drives.
Regards,
Jan 05, 2011 | LaCie (300966U) 1024 GB Hard Drive
I have a Lacie big disk ethernet that has quit responding. it sounds like the hard drive is trying to initialize but then fails. then it spools down and starts over again. can someone help?
The interface board, inside the case, has failed. If the drive is in warranty you will have to take it back. If not open up the case and try another caddy.
Mar 06, 2010 | LaCie 1TB Ethernet Disk Gigabit SATA...
Verbatim 160GB Hard Drive won't boot.
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
Oct 27, 2009 | Verbatim Computers & Internet
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
Powering up my Lacie ethernet disk 250
When I had this problem it turned out to be the power supply unit. Lacie replaced it - if you are out of warranty you can buy them for about £25 - and this solved the problem.
Sep 01, 2008 | LaCie (300770) 250 GB Hard Drive
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Hard drive won't start up at all
Knowing LaCie the drive might need to be connected to a computer, or need a new battery.  If it is not the battery, try connecting the drive to your computer via ethernet or USB  and you might be able to get the data off of it
Jan 02, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie Ethernet Disk (300788) 1000 GB Network Hard Drive Logo
164 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
