Question about Hayward Pool & Spa
Pool heat blows circuit breaker after a few min. of running
  • 139 Answers
If its a gas heater,make sure circuit is overloaded i.e.other appliances on same circ.An electronic ignition pool htr uses a very small amt of electricity.check for proper grounding.
Posted on Jun 24, 2009
My Intex 603M will only run for 5 min or less before it trips it own circuit breaker.?
That unit has a GFCI breaker installed. Those are made to prevent electrocution. IF there is ANY water leakage from the pump into the area that supplies voltage, the breaker will trip. Make sure that there are no damp areas inside the unit and make sure that you have all the wires that it connects to wired correctly and have ground connections.
Jun 24, 2016 | Intex Pool & Spa
Intertherm FEH-015HA. Why does it keep opening breaker?
Avery, if the breaker is properly sized, there is something in the circuit that is causing higher than normal resistance such as possibly loose connections on one end or the other. Check the 'minimum circuit ampacity' (for circuit A and possibly circuit B) on the heater tag and make sure the correct size breaker has been installed. That should be a 15 kw furnace and could either be a dual circuit or a single circuit heat strip. Fifteen kw correlates to approximately 60 amps at 240 volts.
TURN OFF THE POWER and check the connections inside the furnace terminal block for discoloration and tightness. If its a dual circuit, there will be two breakers to turn off. Check to see if it is a dual circuit and if so, see if someone has paralleled those two circuits together inside the furnace. If so, you have to make sure the appropriate single circuit wire and single breaker has been installed.
It is usually recommended to run the separate circuits to the furnace instead of paralleling them together.
Good luck and whatever you do...BE SAFE ABOUT IT .
Dec 05, 2015 | Heating & Cooling
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Swimming pool pump problems
motor overheating replace pump if new install check wiring
Sep 15, 2012 | Pentair Pool & Spa
Pool motor kicking the breaker only after a few minutes .
If the pool pump is running and then 10 minutes into the cycle it trips the breaker, then it is overloading the circuit. The pump is laboring, workingf too hard . The filter shoiuld be cleaned. maybe there is a blockage in the return line to the pool. the other thing could be the wire size to the pump, but you said that it was running last summer . so that should be OK
May 11, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
My neptune electric dryer keep blowing the breaker after ten min
If the dryer is running then blows the breaker , then it is not in the electric circuit, There is a fault in the dryer itself. If it blows the circuit at the same place in the cycle each time then there could be some fault in the heating coil or in the timer circuitry.
Dec 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Outside unit trips the circuit breaker
seems that if it runs for 5 minutes there shouldnt be any shorted wires I would say your breaker needs replaced
Aug 04, 2009 | Weather King 10AJA6001AH Air Conditioner
Heater runs 5-10 minutes then blows the breaker
After raising the water level in the pool I had no results. I bypassed the pressure switch and nothing happened so it was not the switch. Then I turned on the current for a few minutes, this moved something as it works now. So I conclude that the problem came from letting my water level get a little low.
Mar 26, 2009 | Raypak Spapak Electric Spa Heater - Els552...
Estate dryer kicks off circuit
you can check where the cord is connected to the drier did you use the cord off your old drier see if the cord is tight at the back of the drier and the center terminal of the cord should be on the center of the terminal block and why did you buy a new drier hold my rating till were done please
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Oct 14, 2007 | Kenmore 62602 Electric Dryer
Pool & Spa Logo
75 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
