Question about Microsoft Xbox 360 Console
Xbox 360 has three red lights Will not work any sugestions?
  • 69 Answers
Please Let`s be clear on this mater to all Users of X BOX 360s
first its not the "glue stuff" heat sink compound on or under the board that causes
problems . And if you disconect the fan and turn it on your
going to fry your C.P.U. which is far more sensetive to heat than
the G.P.U . The X clamp is the only thing holding down the G.P.U
with almost no force . After the chip heats and cools a few times the chip set
starts to contract the conections till they break open A.K.A R.R.O.D
or the load curent start to skew the timeing A.K.A. lagging freezing and
vertical white lines .
99.9 percent of most failure are the X clamp and when properley moded they dont fail.
its just as simple as that.
if you want to know the truth go to www.all-xboxrepair.com
Posted on Jun 24, 2009
  • 3 Answers
Ok first of all i can say if you got the red ring of death you can fix easy as in 3 steps oh and first i want to tall you that i haved repeared a lot of them my self with the same problem and has worked all the time and left my friends happy.
Well this is how you do it: step 1: unplug evreything and go to the front of the xbox an remove the face plate, then go on each side and remove those plastic covers from each side and be carefull because its kind of treaky( dont brake anything) then go to the back and you will notice that it has about 7 little dash between the xbox opening you got to find a screwdriver thin enough to snap it in there and open the xbox (you should probaly look on youtube how to open the xbox by the way easier to understand) step2: once you haved remove the case and all you will see that only half of the xbox is naked there is still the other pice of the case connected wich it should be the top part of the xbox, so this is what you do remove all the screws on the bottom or the other side were there is no white panaling and sing them with a marker were they go so you know were they go when you have to put it back toghter. step3: once you got it all stripped down to just the mother board and you have disconnected the dvd drive and all unplug the fan cable and pull the motherboard out, then remove the x clamps located at the bottom of each cpu once you have taken them off reapply thermal paste on it and put it back togheter the x clamp. step4: ok this is the triky part this is what you do put connect the xbox with the power cable then put the power button on again and dont connect the fans on just yet very important!!! turn it on and you will notice it has 3 lights flashing rrod so leave it on until it overheats and only has the 2 left side lights flashing after that unplug the cord and leave it to cool down after its cool down plug it back in and the fans with the little fan plastic cover and turn it back on Tada it s back to life plug evreything back togheter and you are done you can enjoy once more xbox magic games. if you have any problelm send an email at nitros581@hotmail.com thanks bye
  • 490 Answers
Its known as the ring of death its a fatal error all original xboxes seem to get and cant be fixed easily, it is caused by the crappy glue stuff they use to stick down the cpu it heats up with use and boils the cpu in the glue and lifts it off the circiut board resulting in the 3 red lights. it can be repaired by yourself but it is extremely trickey and you have to no a bit about circiut boards, if you do decide to do it yourself google how to fix red ring of death and it will give you instructions
Xbox 360 three red lights occasionally
Dave thanks for your question. It appears that your xbox is experiencing over heating issues. Here is a link to an XBOX 360 repair guide for this issue.
Jan 26, 2013 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
RED RING WHEN TURNED ON OFF FOR A WEEK
Nov 26, 2008 | Microsoft Xbox 360 Console
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 08, 2008 | Video Game Consoles & Games
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Sep 05, 2008 | Video Game Consoles & Games
I get red rings when i turn on my xbox 360
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
360 red lights
can you explain more It could just be that the T.V is not matching the system correctly just take it to a shop and ask for the GUI system Check then ask for repair If something is clearly wrong.
Apr 30, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
217 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
