Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
My Canon Rebel XTi has repeatedly had the Err99 message pop up, and it's to the point that it happens, at minimum, every 4-5 shots I take. I've tried cleaning the camera and lens contacts multiple times, but the problem has gotten increasingly worse and refuses to be fixed. I have a 17-85mm Canon zoom lens and I'm not sure what I should do at this point.
    President:
  • 2,187 Answers
There are several issues which may have caused this, one is the CF another are the lenses. I found the solution months ago from this site.
To isolate the cause of the issue, I suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jun 24, 2009
I just bought a canon rebel xt and I have been playing around with settings I am very new to photography. As of right now when I try to take the shot the flash keeps blinking and its says busy and it wont...
It sounds like you might be too close to whatever it is you're trying to take a picture of. Each camera lens has a minimum focus distance listed on it that determines how close you can get to something and still take a picture. Page 45 of the XTi manual talks about minimum focusing distance and describes the camera's behavior.
It's also possible that there is not enough light for the lens to focus. In this situation you might have to flip the switch on the lens to manual focus to take your picture.
So, either try moving further away so the lens can focus or use the manual focus.
In case you are interested, here is a website that discusses the minimum focus distance. Even though the website talks about Nikon cameras you will still be able to use the information.
Also, on page 160 of the XTi manual there is a section titled "When Autofocus Fails" that will give you an idea of what your camera is doing.
Cheers and good luck. :)
Mar 25, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Err 99
err 99 means there is moisture inside of the camera, probably inside the hot shoe
Aug 25, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Why does the word, ''busy'' pop up on the canon rebel xti?
This is the camera writing to the CF memory card. Perhaps your card is a lttle slow, so you will see the message. I use the Sandisk Ultra II CF, labelled as 15Mb/sec and it is very very fast indeed - I don't have any lag with my XTi. Try a different CF, if it is fast enough, the message will go away. Ensure you format the card on the camera too.
Apr 13, 2009 | Canon EOS Digital Rebel XTI Digital Camera
If the flash fires a full charge(eg. in a dark environment) then this message will appear whilst it recharges. If the message appears all the time and you cannot take a photo there is most likely a problem. Try taking some pictures without the flash card to eliminate that first.
Apr 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi - won't shoot
Hi
Sounds like you have shot so many photos you have worn out the shutter box. The box is usually good for about 10,000 actuations... so... sounds like you have gotten far more than that out of it.
I have one XTi with a buddy right now who is a certified Canon, Nikon and Fuji tech and he's putting in a new shutter box for one of my customers. It's the first one he's done so I will see if he wants to keep doing them or not and how much he would want if he decides he will continue to do them for me.
We are an affordable digital camera repair business, if we can help you with your repair then please let us know.
Good luck from Darntoothysam com
Thomas
Oct 04, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Err CF
I had the same message on my EOS/Rebel XTI and the camera shop concluded that one of the pins where the card is inserted into the camera had come loose. They sent the camera back to Canon for repair. Luckily, it was still under warranty at the time.
Chris
Jul 04, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Jul 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Error code 99 canon E0S 450D
Try this:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
41 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
